Results 1 to 10 of 10
Thread: Phase One 645AF (Mamiya 645AFD III) - Good or Bad?
    Nov 2010
    274
    Is there anybody who uses Phase One 645AF (Mamiya 645AFD III?)
    Is the AF fast (relatively) and accurate?
    Which digital back do you recommend?
    Thanks!
    Subscriber Member billbunton's Avatar
    Feb 2010
    Alamogordo, NM
    49
    10
    Re: Phase One 645AF (Mamiya 645AFD III) - Good or Bad?
    Already responded at TPF...
    Nov 2010
    274
    Quote Originally Posted by billbunton View Post
    Thanks!
    NYC
    3,275
    7
    Autofocus speed/accuracy and body responsiveness:
    AFD1/2 = OK
    AFD3 / AF = Good
    DF = Great
    But this of course is highly subjective and dependent on what you're comparing to. It's also partly dependent on how you use the system - for instance one of the largest leaps the DF made over the AF was in low-light autofocusing. A hands on test is the only way to tell how good the AF will be for you.
    Any number of dealers, ourselves included, can rent you a back with the rental cost counting towards purchase, or show you a body in person for free.
    Doug Peterson (e-mail Me)
    __________________
    Phase One Partner of the Year
    Newsletter | RSS Feed
    Buy Capture One 6 at 10% off
    Los Altos, CA
    10,486
    1031
    What Doug said, though I'd rate the AFD2 a teeny bit better on AF than the original. One other point is the AFD1/2/3 can all use film backs, the DF cannot. So my back-up back preference is one of the former.
    home: www.getdpi.com
    Nov 2010
    274
    Thanks! I would use film occasionally... Therefore DF is out of question. The good backs are soooo expensive. My wife is going to kill me!!!!
    Vancouver, WA
    5,801
    564
    I think you need to determine what your frame of reference is for fast/accurate AF. Coming from Nikon Pro DSLRs & glass I'd rate the speed on all of these cameras as merely at best slow (AFD/I/II - haven't tried III/AF) to just about adequate (DF).
    As regards accuracy, so long as it's on one of the three AF sensor points then you'll be accurate, although if the light isn't great or contrast high enough you may have hit two or more focus points to get the one you want. I'm not trying to follow motion with my 645 shooting so prefer accurate mode with just the single AF point - it saves a lot of frustration in so far as I know what to hit to get focus and then recompose.
    I'm not sure if my expectations are too high or whether maybe I've just not drunk the /Phase One koolaid ... either way, I've definitely been spoiled by the excellence of Canikon DSLR response, focus points and accuracy.
    Sep 2010
    Philly area, PA, US
    354
    I have the AFDII and compared with any of the current DSLR (Canon or Nikon) it's a lot slower.
    It feels like the speed of the compact cameras. As far as accuracy, it only has 3 big *** focus points. If you are close to your subject, it will be good. Further away and you risk to pick up stuff around your subjects. At times, I have to switch to manual focus because of that. I don't use it the same way I use my DSLR so I'm not concerned with low light focusing.
    Jun 2010
    144
    I am still using AFD III. If you don't shoot moving object such as kids, it works ok and the accuracy is good. IMO, it is much improved from AFDII. My old AFD II always moves back-and-forth, while AFD III is more stable. However, it is quite clumsy anyway. For shooting kids, I use my 70-200VRII with D3, but for landscape, still portrait, and architecture, the combination of AFDIII and my P30+ are much better.
    If you do not plan to use a technical camera, P30+ can be a good choice. Its used price is inexpensive now since its microlens is a major limitation, but it works great up to ISO800.
    Sep 2010
    Philly area, PA, US
    354
    Quote Originally Posted by topgreat View Post
    It's all relative
