Results 1 to 7 of 7
Thread: Jpeg please !
    Sep 2008
    Near Brussels, Belgium, Europe
    541
    Jpeg please !
    It will be soon possible to send a photo from an SD card directly to a smartphone or iPad. No need for a separate wireless router or any other device anymore.
    http://www.robgalbraith.com/bins/con...=7-11133-11150
    This is really great for shooting outdoor.
    In my case, using a P40+ on a Cambo for architecture, and 'easily' reviewing the shot on my iPod should be really, really great.
    An SD card can be used on a Phase back with a Compactflash card adapter.
    A metal free adapter gives good results (no signal distraction).
    Normally raw files ca also be sent the same way, but duration will be longer (too long ?) and files won't be usable on iPad / iPhone.
    So the missing link, if I got it well, is the 'shoot raw+jpeg' function on the back (as Pentax does).
    As Phase and Hasselblad are already generating jpeg files for displaying on the back, it shouldn't be that complicated to firmware update the backs to record a jpeg version on the memory card too.
    If all that is correct I hope someone at Phase One understands the outstanding added value of such an update !
    Jun 2009
    1,347
    12
    Re: Jpeg please !
    Quote Originally Posted by anGy View Post
    is that an assumtion or proved ("real world")?
    Phase = TIF (~ 200-600 pixels wide) embeded in the RAW file
    NYC
    3,275
    7
    Re: Jpeg please !
    Actually it's not "soon" - it's "now". But only if your standards are very low or you simply enjoy tinkering. For those used to shooting tethered it's a very painful comparison (other than not requiring a cable/computer which is of course very nice).
    I've used these solutions with several bodies (D3, M9, Canon P&S). At best they are "ok". But signal strength, transfer speed (even for a small JPG), and functionality (one way communication only, no ability to tag/sort/name files in a way that persists to the final product, no ability to check focus at 100%) are all mediocre, and stability was only "good" (not production ready IMO).
    Even if the adapter has no metal an M9, D3, and Phase back all have a LOT of metal in the direct area of the card.
    Very exciting area for future development, but currently VERY nascent.
    Unless you are a tinkerer I suggest you keep your head down for a year or two when the solutions will undoubtedly be faster, better, and more functional.
    The level of sophistication of features, speed, stability, and practical usefulness of wired tethering is so high it sets a very high bar for wireless tethering. See for instance the much faster, much more functional iPad application 'Capture Pilot' when shooting tethered to Capture One.
    Doug Peterson (e-mail Me)
    __________________
    Phase One Partner of the Year
    Newsletter | RSS Feed
    Buy Capture One 6 at 10% off
    Sep 2008
    541
    Re: Jpeg please !
    Quote Originally Posted by thomas View Post
    It's an assumption based on the fact that those SD cards + adapters do work on DSLR bodies (Nikon, Canon) accepting CompactFlash cards. But a real test with a DB should be performed to be 100% sure.
    DSLR + SD wifi cards config have been tested on the same site as the fact that metal free adapters give better signal even if cameras are of course containing metal.
    Signal strenght and speed were tested too with very good results in the SD + wifi + separate router configuration.
    No test as been done with the embedded SD wifi and router card as it is not available yet (demo during the CES).
    Sep 2008
    541
    Re: Jpeg please !
    Quote Originally Posted by dougpetersonci View Post
    No cable but mostly no laptop is a serious +.
    An iPad can easily hang on the tripod and be checked for reviewing the shot.
    It is less doable with a laptop.
    Moving safer and faster from one spot to another is also good for speed and creativity.
    Just keep this simple: need to review the shot on a good quality, portable (and not transportable) screen, that's about it.
    NYC
    3,275
    7
    Re: Jpeg please !
    Hmmm. Guess it all depends on what you're comparing to.
    I can assure you I am no slack when it comes to testing such gear. I found the speed to be slow and the signal to require the photographer to have the battery-powered-wifi device in their front pocket if they wanted complete assurance it would be stable.
    But my comparison is a real tethered setup.
    Sep 2008
    541
    Re: Jpeg please !
    My memory tells me that transfer times were around 1" per 700~1000kb but am not sure.
    So a 'DSLR like' Raw + Jpeg with different Jpeg sizes selections via display menu should be great, and flexible for different needs (small (fast) Jpeg selection when composition check only is needed >< large (slow) Jpeg selection for checking details and sharpness for instance).
