Results 1 to 18 of 18
Thread: horseman/CFV
    Brooklyn
    4,043
    1253
    horseman/CFV
    any advice on this pairing? is the cabling or shutter recognition a problem? i'm sure a few of you old bladd'ers would know, eh?
    thanks
    john
    23,623
    2555
    Re: horseman/CFV
    Yes what cord does John need to go from lens to back
    www.guymancusophotography.com
    23,623
    2555
    Re: horseman/CFV
    Look at the bottom and see if you have the flash sync cable . I think that is the output right there on the right side
    http://www.hasselblad.com/media/107193/cfv%20ii.pdf
    Here it is to buy
    http://www.bhphotovideo.com/c/produc...ync_Cable.html
    But let's confirm this
    420
    4
    Re: horseman/CFV
    thanks
    john
    It's simple. All you need is the flash sync cable that should have come with your CFV. One end into the top left port on the back, the other into the sync post on the lens.
    Steve Hendrix
    www.ppratlanta.com/digital.php
    23,623
    2555
    Re: horseman/CFV
    Thanks Steve exactly what I thought
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Re: horseman/CFV
    If you need the cable we have them in stock they are the same ones the Phase One backs use. I think they are $59. Give me a call if you need one.
    Lance
    Lance Schad
    Capture Integration - Miami/Atlanta
    305-394-3196 cell | 305-534-5702 office
    Capture Integration
    My Blog
    [email protected]
    8,498
    44
    Re: horseman/CFV
    John, the proper sync cord came with the back.
    To use it you need to go into the menu > Settings > Camera > Sync
    The trick is to remember to set it back to the 500 when you're done : -)
    Brooklyn
    4,043
    1253
    Re: horseman/CFV
    thanks, boys. next week ought to be a kick. as far as focusing, i expect that popping on the blad ground glass and a loupe will work
    23,623
    2555
    Re: horseman/CFV
    Yes it will
    Brooklyn
    4,043
    1253
    Re: horseman/CFV
    horseman in hand; glad to see it has eyelets for a neck strap! solid little bugger, too
    23,623
    2555
    Re: horseman/CFV
    It sure is . Waiting on cable i know. John don't you have one that came with the camera.
    Lance fed-xed it to you overnight
    Brooklyn
    4,043
    1253
    Re: horseman/CFV
    will be set tomorrow. the kit that came with the camera was a little thin, no problem.
    maybe i can come up with some accessories in my shop...
    Brooklyn
    4,043
    1253
    Re: horseman/CFV
    finally got out there with the horseman. it is challenging
    first, I found the viewer of not much use; no better than eyballing it. best for me was the 90 degree prism finder (blad) on the ground glass back. make sure you set the back to SWC mode.
    that worked extremely well...BUT: you have to take off the CFV back (careful of the sensor, find a good place to put it), that requires that you unplug the cable and pop off the battery (the battery interferes with the Horseman base if trying to tilt off the back to remove it. so battery in the pocket. put on the prism/ground glass. focus and shift. put the back back, (keeping your prism unit safe),the battery back, power up (make sure you locked the shift locks or it might move&%$%^#). remember to close the shutter; take the shot and chimp the histogram.
    now if you want to do a stitch, remove the battery and back, etc., etc.
    all the while at the Navy Yard, I'm trying not to step over the edge of a pier (i had one foot over the edge on a bumper a few times) or get run over with one of those giant cranes (they are creepy, fortunately noisy)
    or drop anything into the muck i'm standing in.
    now to go back to the blad...remember to change the back to 200...oh yeah, have to cock the shutter to remove a lens...etc.
    fun morning, though I'm still getting friendly with the horse
    Phila./NY
    1,146
    19
    Re: horseman/CFV
    John,
    Since you are using a square chip you can rotate the mounting plate in any orientation. I do not have too much experience with the CFV but it may assist you with mounting and unmounting the unit .
    Worth a try.
    Lance
    Brooklyn
    4,043
    1253
    Re: horseman/CFV
    i would have tried that, but then all the menus on the back are rotated also .
    i may make a modified tripod plate so the back can pop right off.
    Brooklyn
    4,043
    1253
    Re: horseman/CFV
    here is a vertical stitch, from four frames
    23,623
    2555
    Re: horseman/CFV
    Takes time and patience. Something I lack. LOL
    Looks nice John
    Los Altos, CA
    10,486
    1031
    Re: horseman/CFV
    John, it is images like this one that prompted me to get the Horseman too. When you can so easily combine four frames into a near perfect stitch at around 3x the native pixel count of your sensor, it sure makes one take notice. Excellent image!
    home: www.getdpi.com
