Results 1 to 12 of 12
Thread: Hasselblad @ 800mm
    Oct 2009
    201
    Hasselblad @ 800mm
    This post is duplicative of my post @ http://www.hasselbladdigitalforum.com and I thought I'd share my results here.
    I've been testing the Hasselblad HTS over the past several months and I am extremely happy with the results. While I do not use it all the time, I find it to be a necessary part of my landscape gear. I've primarily used my HTS with the 28mm through 100mm lenses.
    However, in my testing of the HTS, I attached it to my HC 300mm with the 1.7x in between (300mm + 1.7x + HTS). I did not think the results would be any good given the number of elements the light has to travel through.
    However, I was quite surprised. My H3DII39 (and Phocus) shows the combination to be 800mm, and I did a series of additional tests to determine the quality of the combined glass. Below are samples from those tests at various f-stops (mind you these are not portfolio keepers or award winning shots - I specifically selected some random car for the words on the back and the sign on the left):
    800mm @ f11
    800mm @ f16
    800mm @ f64
    800mm @ f90
    I saved these as 100% JPG to eliminate data loss from compression and the sharpness in Phocus was set to 300/2.0/0/10 - no changes were applied in Photoshop except my copyright, 16 bit to 8 bit, and the Save for Web (to JPG). There's a slight discoloration at the license plate in the f64 and f90 shots; I do not know why. The focusing is very tight and I needed to be precise since the slightest twist pulled me out of focus.
    I will perform additional tests shortly by switching the order of the HTS and the 1.7x and check to see if the results are better, worse or how they differ. (PM me if you're interested). Again, I'm pleasantly surprised by these results and it's good to know I have 800mm with my Hasselblad gear. The HC[D] glass is quite good (and perhaps under rated by some).
    Kind regards,
    Derek Jecxz
    http://www.jecxz.com
    http://www.facebook.com/derek.jecxz.photographer
    PS: I did not feed the sheep.
    Jan 2009
    Jeddah / Saudi Arabia
    126
    Re: Hasselblad @ 800mm
    Derek, good job and impressive results, much better than expected. How did you support this setup? Any additional support to tackle the camera's moment of inertia?
    Regards from the Red Sea,
    Udo
    Oct 2009
    201
    Hi Udo,
    I supported the setup on the tripod collar on the 300mm. It was very well balanced.
    Kind regards,
    Derek
    May 2010
    Perth, Western Australia
    138
    very cool cheers for showing Derek.
    www.williamophuis.com
    Hassy H4D-40.
    Brooklyn
    4,043
    1253
    I'm going to try this, looks like fun. mine will be with the 210, 1.7, HTS, though ;(
    NYC
    3,275
    7
    I'm unclear here. You say 100% JPGs. I assume you mean 100% quality rather than 100% crop.
    Could you post 100% crops, for instance of the license plate for each of the above views? Hard to tell much about the quality from these <1 megapixel images.
    Nov 2008
    UK
    561
    Wind it in Doug. :/
    Derek is simply saying he has found a way to get 800mm on his camera.
    Yes it is using a combo we don't recommend, but I'd it gets a shot that would otherwise be impossible, who cares?
    I don't think Derek's post was a 'wow look at the quality', but more of 'this works for my needs'.
    You must also respect Derek would not use a combination that would compromise his quality based on the required output.
    David.
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Never tried this but can you use two teleconverters with the 300mm? Might be a bit dark for focusing but will it be free of vignetting etc?
    1.7X1.7X300X1.5= 1,300mm
    Nov 2008
    UK
    561
    Might be fun!
    Probably very hard to focus but I'll have a go next time in Sweden. Give the lens designers a heart attack.
    Oct 2009
    201
    Quote Originally Posted by yaya View Post
    I'm reviving this old thread because I actually just tried this combination! A local camera shop had a used 1.7x converter and I did a series of tests. Not sure if I'd ever use the 3 lens combination (I didn't purchase it), however, you never know how else it can be used for (creatively speaking). It was difficult to focus; here are two examples, but they've been Saved to Web and scaled to 1024 wide, so use your imagination, I guess?
    100mm + two 1.7x's - 6 sec @ f16 (effective 280mm)
    300mm + two 1.7x's - 11 sec @ f25 (effective 850mm)
    Kind regards,
    Derek Jecxz
    Senior Member stngoldberg's Avatar
    Apr 2011
    newport, RI
    801
    12
    I use two 1.7 extenders on my 300mm quite often for wildlife shots mounted on my tripod. It does take patience to focus-but the results rival any of my Nikon 500mm results with a 1.4 extender I have posted before on this site with this information. Because the Hasselblad is limited to a shutter speed of 1/800, sec the setup is only user friendly if the wildlife is at rest: however the huge prints attainable wow everyone that I show them to
    Stanley
    Oct 2009
    201
    Hi Stanley,
    I did not know this! I saw Yair's post a while ago asking about the combination and finally tried it. Glad to hear it's commonly used. Can you please post some links? Be well.
    Kind regards,
    Derek
    Quote Originally Posted by stngoldberg View Post
    Stanley
