Results 1 to 6 of 6
Thread: B Setting on P30 back with 503CW
    Jul 2009
    455
    I am having trouble with the 503CW and a P30 back (not the P30+). The images are fine all up to 1 sec (or at least after I found a lens without lens shutter issue with low speed). However, with B, first, it always terminates no more than after 5-6 secs even if I hold the shutter release down longer, and second, it never seems to obtain an image.
    I have checked the B setting does hold the lens shutter open by removing the back and raising the mirror so I can see through the iris. The lens shutter seems to operate as it should.
    I tried two different sync cables with the same result. I also tried raising the mirror and again the result is the same.
    Any idea? I know the P30 back doesn't do as low light as the P30+, but it's almost like hardly any light is admitted.
    Thanks.
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Re: B Setting on P30 back with 503CW
    Have you tried another lens to see if maybe that is causing the issue? Sometimes the sync connector on the lens goes bad and can cause issues. It seems you have already tried two cables.
    Lance
    LANCE SCHAD - Digital Transitions - Phase One,Mamiya | Leaf,Arca-Swiss,Cambo, Profoto
    direct/cell:610-496-5586 office:877-367-8537x224
    http://www.digitaltransitions.com email:[email protected]
    Jul 2009
    455
    Quote Originally Posted by lance_schad View Post
    Lance
    Yes, I tried two lens. One is the 80 Planar and it has slow speed problems (red shifted images) and B problem as described. I am renting a 50/CFi that works great with the slow speed but has the B problem.
    Jun 2008
    Tampa, Florida
    51
    Richard:
    It is almost certainly the lens. Their are two shutter sync internal from what I have been told and the slower shutter speeds setting make it impossible to close the circuit and make the capture. You may also check to make sure you are set to short latency and toggle that to see if it reacts any different but I would put my money on the lens being bad at those settings. Have you tested this with both tether to a computer and to a CF card. I cannot imagine the tether operation having anything to do with this issue. I have seen this in a demo before but it was isolated to one of the guys lenses.
    Good Luck
    Sincerely,
    Chris Snipes
    Sales Manager, Florida
    Capture Integration
    http://www.captureintegration.com
    2010 Phase One Partner of the Year
    404.522.7662 Atlanta
    305.350.9900 Miami
    877.217.9870 National
    813.335.2473 Cell
    Sign up for our Email Newsletter
    Subscribe to our RSS Feed
    Quote Originally Posted by richardman View Post
    Jul 2009
    455
    To put a closure on this: yes, it's a lens problem. During some point in the history, Zeiss made some "newer" lens that shut off the sync signal under B to save power or something. This does not affect normal usage using flash and film, but cause the digital back not to operate correctly.
    Thanks for the help!
    tetsrfun
    I tried my 40 CFE using the flash sync and "B" and it works so must be the CFis that have the "problem".
    Steve
