Results 1 to 5 of 5
Thread: problem with files, it happens sometimes...
    May 2009
    Marseille, FRANCE
    972
    sometimes i have this can of file... (aptus 22)... where does it come from ? how to avoid it ?
    thanks
    Vancouver, WA
    5,802
    564
    Re: problem with files, it happens sometimes...
    1 - is it related to a particular cf card? If yes, you're lucky.
    2 - If not, I strongly suspect that it's the processor/logic board unfortunately. I had a Kodak DCS645M back that did this a while ago and it was the main board that caused the image buffer write problem. I hope it isn't that ... It was cheaper to replace than get fixed.
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Quote Originally Posted by archivue View Post
    thanks
    Most likely this is a sync issue with one of your lenses at certain shutter speeds. Usually this starts happening as the pc socket starts wearing out so it could be worth having the lens serviced
    You can also submit a support case and send us some raw files so that we can confirm that this is indeed the issue
    Link to support site
    cheers
    yair
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by yaya View Post
    You can also submit a support case and send us some raw files so that we can confirm that this is indeed the issue .
    cheers
    yair
    Yair
    This is an outstanding service offer .
    I have never experienced something like that from an other brand .
    Regards . Jürgen .
    May 2009
    Marseille, FRANCE
    972
    Yair rocks as usual !
    i will send a file when i'm back home !
    it happens with several CF card !
    i've stop using lexar UDMA, too much problem... i'm using Sandisk extreme.
