Results 1 to 5 of 5
Thread: Horseman SW-DII, Aptus 75 and Digitar 55mm
    Senior Member JimCollum's Avatar
    santa cruz, ca
    936
    155
    Tried out the 55mm digitar lens on the Horseman with a Leaf Aptus 75s. The files were processed in LC11 with sharpening set to 0, taken at ISO 100. These are 100% crops
    f4.5
    f5.6
    f8.0
    f11
    santa cruz, ca
    936
    155
    Re: Horseman SW-DII, Aptus 75 and Digitar 55mm
    f16
    f22
    f32
    f45
    23,623
    2555
    Jim looks like F11 is optimum and is starting to go at F22 but F16 still looks real good . Hard to tell between F11 and F16 though which is better . Leaning at F11 myself
    www.guymancusophotography.com
    ericstaud
    Hi Jim,
    I am using an Alpa with the 24, 35, 47, 72, and 100 digitars. I find that F11 is generally optimal but I often stop down more. With the 47 and 35 lenses the outside of the image will improve with more f stop. When shooting a high rise I will often shoot at 22 so that the top of the building will improve a little in sharpness while the center of the image circle will suffer a little in sharpness. In the end, the apparent sharpness of the image will be more uniform from top to bottom.
    santa cruz, ca
    936
    155
    Quote Originally Posted by ericstaud View Post
    Hi Jim,
    These were taken on center. when i have time i'll take a look at the outer area as well. I'm also testing the 135mm
