Results 1 to 14 of 14
Thread: H4D 31 dust on sensor
    drmytan
    Found dusts on my image even after the CCD sensor was blowed and cleaned up and no change of lens. Called the local supplier and told it's common issue as dust might get in through the minor leaks. And advised me to open the digital back and blow each day! I somehow can't accept the explanation. I am new to the MF camera. This has annoyed me so much. Thanks for help
    Jan 2010
    528
    Re: H4D 31 dust on sensor
    Yes, this is normal. No problem whatsoever. It is easy to take off the back. Take off the viewfinder, below that in the center push the black button forward (towards the lens mount) and push the button on the side (left) in and rotate slightly backward. Now the back can be taken off.
    Blow off the sensor and if necessary wipe it with something like a pec-pad and eclipse fluid.
    Amazing this hasn't been explained or shown to you by your dealer. This is nothing to be annoyed about, normal thing and actually it is much easier to clean your MF equipment than a 35mm DSLR.
    I use my MF stuff daily but find it unnecessary to clean it everyday. I do so the moment I see spots. Regularly but certainly not daily.
    Mar 2010
    1,579
    Quote Originally Posted by drmytan View Post
    Make sure you ground yourself and power is off, as there's an electrical charge on the sensor that pulls dust in. Static electricity should be discharged before cleaning any camera. As a previous owner of an H4D, I found this camera to be more prone to sensor dust than any other camera, perhaps because there's more places for dust to enter. Also clean the viewfinder and remove ground glass for cleaning too. Use a hand blower brush when possible and watch the tip of blower brush on sensor! Although, I would only recommend cleaning the sensor with a Pec - Pad if there's actual spots that aren't removed with a blower brush and ONLY use one side of a Pec pad per swipe. otherwise you'll be dragging dust over the sensor.
    Brooklyn
    4,043
    1253
    that big mirror flopping around stirs up the dust, so clean the mirror chamber as well
    tetsrfun
    The Visibledust sensor loop is also quite useful. It's one of those things that I would see the ad and say "Who would be dumb enough to buy that" and now I think that it is really helpful.
    Steve
    Mar 2010
    1,579
    Excellent point! I agree, the box has lots of air movement! Also, the company that makes PecPads, also makes "brush off" it's a cleaning brush that allows you to ground the static charge. http://www.photosol.com
    2,794
    We should mention that the MFDBs are the easiest of all the sensors out there to clean as you are not reaching into a deep recess to access the sensor and cover.
    Remember, dust in the form of silica particles is harder than the cover and will scratch it if you put enough pressure on the pad when cleaning. So first attempt to blow off any large particles before you attempt wet cleaning.
    All of the Visible Dust products are well designed...their hand blower is one of the few filtered blowers that minimizes condensation. I have used the brushes for years with moderate success ... usually need to use sensor cleaning fluid to finish but it is so fast and easy on a back.
    It is much better than spotting scanned film.
    Bob
    drmytan
    Thanks guys
    2,794
    Very nice!
    Bob
    N.S. Canada
    2,010
    Indeed
    Aug 2010
    New Jersey, USA
    509
    One thing that surprised me when I added H3d2-39 was how much dust gets on the sensor. Like others, I see no need to clean every day, but it does seem to need a sensor air blow more than my dslrs.
    Nov 2008
    UK
    561
    Don't forget in Phocus now you have the dust removal tool which you can batch modify over a group of images.
    drmytan
    THANK SO MUCH EVERYONE WHO RELIED. REALLY APPRECIATE.
    Dec 2010
    Montreal, Canada
    37
    I find cleaning a MF sensor much easier then cleaning a DSLR.
