Results 1 to 6 of 6
Thread: H4D/60 Back on RZ?
    8,498
    44
    H4D/60 Back on RZ?
    I still have an entire set of RZ lenses from fisheye to 210 APO including all the fun stuff like SBs and T/S adapter, soft focus 180, etc.
    I'd love to slap my H4D/60 back on a RZ, and thought I had seen a dumb adapter to accomplish this ... typical use of sync cord lens to back and I'd use it mostly tethered anyway, so powereing the back isn't an issue.
    Anyone know which adapter is needed and where I could get one?
    I presume I would NOT need the RZD version of the camera, but if anyone knows of a RZD for sale let me know please. Might as well get that over the reg. RZ.
    I'd love to have the new Mamiya RZ33 kit, but no way can I swing $18K.
    Any help most appreciated,
    -Marc
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Re: H4D/60 Back on RZ?
    RZIID won't give you anything over your RZ unless you're using a Leaf/Mamiya/ Phase back in AFD mount with the Mamiya HX701 adapter (no sync cable)
    We make an H adapter but the small latch at the top of the HxD back gets in the way so it won't fit unless you "modify" it...
    ECO-Digital also make one but again that latch is in the way...
    Good luck!
    8,498
    44
    Thanks Yair,
    By "Modify it." do you mean modify the adapter, or the H60 back? (which is NOT going to happen : -)
    I figured if I have to get a body, might as well be the D version since it opens the possibility of a later Aptus 10 or 12 back without cabling it.
    -Marc
    Feb 2009
    1,083
    6
    I will watch this thread because i have RZII non D, it will be nice if there is an adapter to use my H4D60 on my Hasselblad V series [501CM], i can't go and replace this H60 for Phase One, adapters if available will be way cheaper than a new DB P1.
    Tareq
    Oct 2008
    Canada
    163
    http://cgi.ebay.com/Leaf-adapter-RZ6...item2562a2dd5f
    Marc.. here is your answer. Snap it up man!
    8,498
    44
    Quote Originally Posted by Dolce Moda View Post
    Hmmm, that seems to be it. Thanks!
    The latch at the top of the H4D/60 back seems to be accommodated on this one. It has a release lever. Works on the seller's H3D/39 ... so it should work for any H3/H4 back.
    -Marc
