Results 1 to 6 of 6
Thread: ExpoDisc vs GrayCard
    Mar 2008
    337
    can I use ExpoDisc with a Sinarback 54M / Contax 645 ?
    It looks like Expodisc is faster and easier to use, potentially more accurate, more durable and easier to carry than a gray card.
    Thank.
    thsinar
    Re: ExpoDisc vs GrayCard
    hi Evgeny,
    I am not sure to understand exactly why a grey card should be troublesome to take with you: there are small sized ones, about A5 or A6.
    Best regards,
    Thierry
    Quote Originally Posted by evgeny View Post
    Thank.
    ddk
    Thank.
    It depends on the camera and the lighting conditions. I found expodisc great for single lighting conditions but not for mixed lighting, then I had to use a gray card. I also found out that my Fuji S5s don't work well with the expodisc, can't tell you why just that the WB is always off if I try to use it. In the end you're going to need a gray card too with your expodisc.
    23,623
    2555
    I use a WhiBal card and I find that works the best. Or lately I have a calibration card from CI that i use and just put it flush on the lens and works really nice
    http://www.pictureflow.com/products/whibal/index.html
    http://www.captureintegration.com/so...aturedproduct/
    www.guymancusophotography.com
    Los Altos, CA
    10,486
    1031
    You should know that the Expo-disk exhibits fall-off toward it's edges, so is not advisable for a color-cast correction tool; here the Capture Integation/Phase Pocket LCC card is faster and more accurate and only about $20. I also find that a good gray card is easier to use than the Expo, and faster in most cases, because you don't have to mount it. For this I prefer Betterlight's super-gray card. Not 18%, more like 12%, but very neutral and non-reflective; also about $20. I can WB just about any situation with these two tools.
    home: www.getdpi.com
    Mar 2008
    337
    Thank all for replies!
    Thierry, if I point gray card at an angle to the camera it will not be exactly read as 18%. Is that right?
