Results 1 to 5 of 5
Thread: phocus and white balance
    Brooklyn
    4,043
    1253
    using my H39 back, set to daylight, and shooting in daylight, i find all my shots come in way off. I can sometimes pick a neutral spot to balance in Phocus or just visually tweak it in, but would like to know why it is so off to begin with. I have Phocus also set to daylight. I realize i can take a shot with a test card, set a custom wb, etc.
    before tweaking, temp comes in at 5300, tint at 10. i have to set temp down to as much as 4300 adn tint to -20 or more.
    thx
    Apr 2008
    313
    Re: phocus and white balance
    Jim are you applying a setup as the images come in?
    Brooklyn
    4,043
    1253
    no, standard is the setting when importing, that was the first thing i looked for as well
    Apr 2008
    313
    Seems odd Jim, the three backs I have here all produce a pretty decent daylight looks using that pre-set. It might pay to modify a couple of images to "Standard" just to be sure.
    Mar 2009
    Massachusetts and Vermont
    948
    thx
    This was a "known" issue with the original H3D-39s. All of the files had a distinct red cast. I had Hasselblad send my H3D-39 back to Denmark on warranty to be calibrated. It worked fine after that. My understanding is that the H3DII-39 and later cameras all came from the factory properly calibrated.
