Results 1 to 9 of 9
Thread: Schneider 35XL on Cambo wide rs on IQ180?
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Has anyone tried this combination yet? There is a lot of somewhat worrying stuff going on about shifting Schneider wides on the 180 and if it's going to be a vale of tears and testing, I'd rather be warned before I take delivery!
    Thanks in advance
    Tim
    Sep 2010
    UK
    1,387
    Re: Schneider 35XL on Cambo wide rs on IQ180?
    My guess......... worse!
    SK 43XL Flange Focal Distance 49mm
    SK 35XL Flange Focal Distance 37mm
    Senior Member etrump's Avatar
    Jan 2009
    1,206
    Quote Originally Posted by gazwas View Post
    ditto
    Jan 2008
    South of England
    3,295
    Thanks Guys. Just goes to prove that there's no free appetisers, however much lunch costs....
    Mar 2011
    215
    14
    Also important to note, I find the adapter interphase for the camera is essential for this system. I found my DF, Hassellad H mounts to be solid fit but my 2 Hasselblad V mount are very loose fit to a point where I can push and pull the digital back in and out. I paid alot for these two adapters and cannot even use them. I will not resell them to other photographers and put them through this painful process. Unfortunately, I was not told and found out much later in time. Thus, try out the interface for your digital back mount first before getting into the system. As for the camera it is great and very underrated.
    Feb 2011
    102
    Do you mean the looseness is between the interface plate/camera body, or interface plate/digital back?
    Mar 2011
    215
    14
    It is between the digital back and the adapter mount where the looseness occur. Is there a solution to this problem? I wish Cambo would take the responsibility to fix this adapter interphase for the Hasselblad V mount digital back.
    Feb 2011
    102
    Quote Originally Posted by MP7 View Post
    No idea. I'm still waiting on my new back in V mount, so I guess I'll found out for myself soon.
    Mar 2011
    215
    14
    I will try to see if I can fix this problem and if I am successful I will let you know.
