Results 1 to 16 of 16
Thread: H4D-200MS
    Apr 2010
    35
    Manchester/Jerusalem
    2,652
    290
    Re: H4D-200MS
    Wooow that's going to need some serious computer power!
    Aug 2010
    New Jersey, USA
    509
    Re: H4D-200MS
    Got the email about it and it's on the www.hasselbladusa.com site. Didn't see a price. Need to make sure I'm sitting down when I find it. lol
    8,498
    44
    Re: H4D-200MS
    The samples are mind blowing. Like nothing I've ever seen ... truly a world class studio machine that can be used for everyday shooting when desired.
    The camera operates as a 50 meg single shot, 50 meg 4 shot and 200 meg 6 shot.
    Having used a multi-shot before, I can say this has to be the highest IQ "usable" studio camera I've ever seen.
    Multi-Shots are a blast to use BTW ... my puny 39 meg MS was spot on for color accuracy and virtually eliminated retouching issues and moire' ... so I can't imagine what this pup will do.
    -Marc
    Nov 2008
    UK
    561
    Re: H4D-200MS
    -Marc
    Glad you like Marc!
    We love the products capabilities and it was received very well at the test sites.
    David
    Dec 2010
    Warks, UK
    550
    Re: H4D-200MS
    Quote Originally Posted by David Grover / Hasselblad View Post
    Glad you like Marc!
    David
    Hi, David .. is the 200Mpx Bayer interpolated?
    Senior Member bensonga's Avatar
    Alaska
    2,416
    819
    Re: H4D-200MS
    I am really impressed with the products Hasselblad has been coming out with recently. If I could afford a new high end MFDB system....it would be an H4D-xx, for sure. This one is amazing.
    Apr 2008
    Seattle, USA
    400
    Re: H4D-200MS
    The 200MS looks amazing.
    I'm trying to figure out if the 6-shot uses any interpolation. I've read the PDF on how it exposes and I'm still a bit confused.
    First, I'm assuming a bayer pattern:
    GRGR...
    BGBG...
    Shot #1: Unshifted, looking at the upper left corner pixel, we'd get the green channel.
    Shot #2: Shift up one pixel and now you'd have the blue channel at the upper left corner.
    Shot #3: Shift one pixel to the left from the original position and now you'd get the red channel as well. Now we have full color for (almost) every pixel position for a 50MP shot.
    Repeat the above process 1/2 a pixel to the right, 1/2 a pixel down, and 1/2 a pixel right and down. That gives me a minimum of 12 shots (16, if we want 2x oversampling on the green channel which can be useful). How is it possible to get double the horizontal and double the vertical resolution without interpolation in only 6 shots?
    David, can you help?
    Thanks,
    -Brad
    Member Arjuna's Avatar
    Mar 2008
    Calgary, Alberta
    203
    Re: H4D-200MS
    from the press release, e.g. dpreview: "The H4D-200MS uses an extension of the company's sensor-shift, multi-shot (MS) technology to create a 200 megapixel file from six images taken at slight offsets. It can also use the four-shot mode used by the H4D-50MS that shifts the sensor by one pixel in each direction to capture all colors at each position. The latest approach adds 1/2pixel offsets to increase the captured resolution to 200MP."
    The four one pixel shifts gives you a non-Bayer 50 MB: each image pixel get sampled by red, green, blue, and green sensor pixels. The same four shifts at 1/2 pixel offsets would give you the 200 MB of resolution, but each image pixel has one sample direct from a (red, green or blue) sensor sample, and three samples that are each from half way between two sensors. If you kept just the direct samples, you would have a 200 MB Bayer image. My guess is that the three intermediate samples would give you better than Bayer colour, but not quite the true colour of the standard (50 MB) MultiShot, hence the two extra shots/samples in order to be able to calculate a true colour, i.e. non-Bayer, 200 MB image. Just a guess.
    Apr 2008
    Seattle, USA
    400
    Re: H4D-200MS
    I think I just figured it out.
    Shot 4: shift sensor to the right of original position by 1/2 pixel. This gives green value of second pixel in the first row of the final image.
    Shot 5: shift sensor up by 1 pixel from previous position. This gives blue value of same pixel.
    Shot 6: shift sensor 1 pixel left from shot 4 position. This gives red.
    These last three shots were all offset from the first three by half a pixel, so almost all pixels will have all three colors sampled (two edges at the edge if the sensor will be incomplete, but they could be easily discarded).
    Not sure if that makes sense in text, but it seems to work, to my mind, at least. Clever!
    Best regards,
    Brad
    Oct 2008
    Saffron Walden, UK
    1,983
    58
    Re: H4D-200MS
    How long does the process of taking the six shots that make up one image take? Is it all automatic?
    Quentin
    Quentin Bargate
    etrigan63's Avatar
    Earth, Sol System (near Miami, FL)
    2,501
    21
    Re: H4D-200MS
    I have seen demos of the multi-shot system and it is all controlled by Phocus. This is a tethered camera setup. Phocus calls the shots and combines the images automagically.
    Carlos Echenique | Carlos Echenique Photography |Olympus OM-D E-M1 MK II | Olympus Pen-F - M.Zuiko 17mm f/1.8, M.Zuiko 25mm f/1.8, M.Zuiko 45mm f/1.8, Rokinon 12mm f/2 NCS, M.Zuiko 75mm f/1.8, M.Zuiko 12-40mm f/2.8 PRO, M.Zuiko 40-150mm f/2.8 PRO
    Nov 2008
    UK
    561
    Re: H4D-200MS
    Quote Originally Posted by BradleyGibson View Post
    Best regards,
    Brad
    Hi Brad,
    Basically the 6 shot does the same 4 shots as the Multi shot (RGBG) and then a half pixel movement in both directions.
    Product Management are writing up a clearer tech explanation and I will post it here when ready.
    David
    Nov 2008
    UK
    561
    Re: H4D-200MS
    Quote Originally Posted by Quentin_Bargate View Post
    Quentin
    Hi Quentin,
    It is indeed all automatic and the 6 shots are covered pretty quickly. If you have decent flash equipment that recharges fast enough then there is only a second or so between each captures.
    Older flashes that need longer to recharge or reach a better stability can be helped out by adding a flash delay to slow the capture rate down.
    Assembly of the six shot is wholly dependant on how powerful your machine is.
    David
    8,498
    44
    Re: H4D-200MS
    Basically, Multi-Shot doesn't add much time to your capture process but saves huge amounts of time in post work ... especially if you are outlining anything, or if shooting items where color accuracy is critical ... plus no moiré issues with intricate patterns.
    The tethered work flow is exactly the same as with a single shot ... all test shots to adjust lighting and composition, or discussion with clients /art directors are done single shot, then when ready to shoot the final image you just click the MS icon in Phocus and the software takes command. You do not even have to adjust the lighting, it is all figured out and exposed correctly.
    As David said, there is a section in Phocus that allows you to set the flash delay to accommodate your specific strobe gear's capability, or the level which you have set the lighting as it relates to recycle times. I had my CF/39MS set to a 4 or 5 second delay between each shot because I often max'ed out my strobe system shooting stopped down for DOF. With other applications I could set it to shoot faster.
    -Marc
    Oct 2008
    Saffron Walden, UK
    1,983
    58
    Re: H4D-200MS
    Sounds impressive! Not sure I need it as my H4D-50 does what I need already, but that is not to say I don't want it
    Quentin
    Quentin Bargate
