Results 1 to 4 of 4
Thread: shift/rise/fall vs. tilt/swing
    Senior Member danlindberg's Avatar
    Aug 2010
    Spain & Sweden
    1,196
    I do not know if this is a stupid question, but I read in many places about the different "issues" when applying shift/rise/fall. However I do not find any comments on any problems when applying tilt or swing. Does this mean that tilt/swing is a non-issue and can be played to its full potential without bumping into nasty colourcasts or other artifacts? Does imagecircle also play a role on how much tilt/swing that can be applied?
    Thanks for clearing up this
    Alpa FPS MAX TC | Alpagon 32Hr | Helvetar 75 | Schneider 120N | Leaf Aptus II 5 Leaf Credo 60 | www.danlindberg.com
    Los Altos, CA
    10,486
    1031
    Re: shift/rise/fall vs. tilt/swing
    There are only a few tech cameras that allow for lens tilt, and even fewer users using them, probably why you don't hear much about it. A pure lens tilt -- one whose axis is on the optical center-plane of the lens -- will not directly alter the angle of the light path as it strikes the sensor, so theoretically if a centered and zeroed lens did not require an LCC, neither should the tilted lens. However... First off, very few of the existing tech cameras that tilt will offer a pure tilt, so will likely impart some amount of shift and their own brand of color cast associated with it. Second, many lenses impart a color cast even when zeroed and centered (especially short focals), it just isn't always prominent enough to be noticed in a typical image -- but shoot the LCC for that frame and you can often read several points of color cast across the frame.
    So my bottom line reco is this: If you shoot a tech cam and want the ultimate in image integrity, ALWAYS shoot the LCC even when you're totally zeroed. If you shoot a tech cam that is always centered and zeroed, a-la the Alpa TC, then at least shoot a set of standard LCC's for each lens aperture you regularly use so you can measure and see they'll be needed.
    home: www.getdpi.com
    Shashin's Avatar
    May 2011
    Florida, USA
    4,501
    141
    A lens tilt does not affect the sensor in regards to color cast, but will start putting less desirable areas of the image circle in the image.
    A sensor tilt will cause a color cast as it increases the angle light strikes the sensor, although it can remain in the lenses sweet spot.
    But both are a matter of degree rather than tilting is simply bad. Most things can be corrected.
    The image circle of the lens just defines how much room there is for movement.
    BTW, I always do an LCC with my Phase backs regardless of the camera movements.
    Aug 2010
    Spain & Sweden
    1,196
    Excellent! I appreciate very much your detailed answers It helps a lot!!!!
