Results 1 to 38 of 38
Thread: Crazy LCC idea
    23,623
    2555
    Crazy LCC idea
    Not sure what the hell I am thinking here but sitting on the back patio i came up with this crazy idea. Yea maybe I need more sleep. But hear me out and have no idea if this would even work. But might be worth a try . READ my quote below in signature..
    I'm sure some engineer, scientist or math guru will shut this down but screw them. LOL
    Okay say your on a Tech cam with a 43 schneider for example and your doing a stitch with back in vertical position. For a base LCC to store in C1 for example. Say you did a 2 shot stitch than did you 2 shot LCC. Now here comes the fun part . You actually stitch the LCC first and make a Tif file. Not sure you can apply a LCC correction on a Tif but say a file extension you could. So after you make the 2 shot LCC stitch you do the LCC correction and store that. Than just process out your normal 2 shot images stitch going forward than bring it back in C1 and apply that 2 Shot LCC stitch. Here you could just happily go along shoot all day and make 2 shot stitch shots than process them out and simply apply the double LCC . Seems to me this would save a ton of time and simplify the process. Okay question would it work and would even CS5 figure out how to stitch a LCC without any detail in it. Maybe not?
    I know I'm going to pay for this one but hell with it. Photography is about experimenting. Would anyone like to try this and report.
    Yes i made the appointment with the shrink already 10 am the white truck pulls up. LOL
    www.guymancusophotography.com
    Senior Subscriber Member
    San Francisco, CA
    1,306
    Re: Crazy LCC idea
    One problem is when you stitch two exposures there is some blending and line detection going on along the stitch. It's rarely stitched along a straight line, if for no other reason than to correct small errors in registration. When forced to stitch across a gradient blending is used. The LCC stitch would have to reflect this.
    Jun 2009
    1,347
    12
    Re: Crazy LCC idea
    - you can't apply LCC to a TIF
    - it's much easier (and much faster) to apply LCCs to a number of shots in C1 simply by copying the LCC setting of the actual LCC shot and applying it to a selection of shots (i.e. select all the shifted shots in question with the LCC shot as primary variant ... then simply click ALT + COPY/APPLY)
    - working with TIFs in C1 is limited to quite a small color space ... so your workflow would through away the full potential of the files
    23,623
    2555
    Re: Crazy LCC idea
    Okay thanks folks. That is making sense was just looking at shortcuts
    Los Altos, CA
    10,486
    1031
    Re: Crazy LCC idea
    It would also be tough for software to find definitive detail to stitch a pair of LCC's together.
    Bottom line is doing them after each shot is pretty easy and fast -- and if you do them religiously, you never have to hunt for the right LCC to use for any given frame.
    home: www.getdpi.com
    4,333
    Re: Crazy LCC idea
    Not too crazy an idea and I wonder why I never thought of it...
    That said I don't see how it would work. The thought of stitching 2 or more LCCs seem to be counter productive to the whole idea of doing an LCC.
    Jack's correct - once you have a workflow figured out it becomes second nature and fast - shoot LCC - capture image - shoot LCC - capture image. I do this for every image I shoot unless I don't make a change in the position. The first thing I do after setting the tripod up is shoot a LCC. I'll also shoot a black screen (either hand or lens or hat or lens cap) when I change locations or to set a pano apart of other images.
    The best shortcut is a good workflow that works best for you.
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Re: Crazy LCC idea
    Just teasing you guys but you can now skip LCC and go straight to stitching in C1 if you're on a Leaf back:-)
    4,333
    Re: Crazy LCC idea
    Quote Originally Posted by yaya View Post
    Show Off!!
    Don Libby
    Blog
    Tucson AZ
    23,623
    2555
    Re: Crazy LCC idea
    You need to learn how to share Yair. LOL
    May 2011
    San Francisco
    104
    Re: Crazy LCC idea
    Along the same lines (i.e. reducing the LCC processing pain)...
    I stitch a lot (~90% of my work). Mostly 2x2 with a P65+ (IQ180 soon, I print BIG:). I create LCCs for every shot (for various reasons, but mainly because LCC is easier and more reliable than taking notes on each shot (voice memo recording on the back would be nice, BTW)), so after a good outing, I can be faced with processing upwards of a hundred LCCs. This is by far the most time consuming and uninteresting part of my process. It seems to me it would be simple to implement batch processing of LCCs in C1. Select all the LCCs and then let it cook over night. I always use the "exclude dust" due to the time a full LCC takes. If I could batch process LCCs, I would really care how long.
    Anyway, if anyone from Phase is listening, please, pretty please, batch LCCs.
    Mar 2010
    Germany
    253
    Re: Crazy LCC idea
    Quote Originally Posted by alan_w_george View Post
    +1. This would be terrific!
    Chris
    May 2011
    Hong Kong
    691
    Re: Crazy LCC idea
    It's definitely doable. Using something like autopano pro, you can obtain a layered stitched pano, then you'd have all the masks to drop in the LCC's. That part could be automated. I know a lady wrote CornerFix for the M9, which is essentially the same thing. The processing (I mean the actual code) in cornerfix could be used to fix the layers in the stitched file.
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: Crazy LCC idea
    I really do not know how consistent the lenses are for centering and so forth, but if you know the lens and you know the sensor, and if the shift were know (via controls) than an approximation of the lcc could be computed.
    The stitch first lcc later is a problem since it is not cler which pixels cale from which frame unless it is kept in layers.
    then it does get interesting but more complicated rather than more simple.
    -bob
    Member LonnaTucker's Avatar
    Dec 2010
    Phoenix, Arizona USA
    45
    Re: Crazy LCC idea
    That's right Guy, you don't have to come up with crazy LCC schemes when you are a Leaf user!
    What I have always appreciated is that Leaf has given it's users multiple options for lens cast corrections (and also raw file processing) and now takes it a step further with corrections available through the DB.
    Also, Leaf's LC11 software with LCC correction is much faster than C1 and I can output corrected .mos raw files that can be processed in Lightroom, C1, Raw Developer, PS Camera Raw, etc.
    Yair, I still like the little stand alone software LCC corrector from a few years ago. I wish that would be updated for use with current Macs.
    May 2011
    San Francisco
    104
    Re: Crazy LCC idea
    That's a tad disingenuous.
    From what I understand, you still have to create the LCC in software and then load the LCCs in the back. AND you still have to select and apply the LCC to the image, you just can do it in the back/in the field versus in software/post.
    You make it sound as if with Leaf your LCC days are over, which is far from the truth. But don't get me wrong though, it is a step in the right direction but not the final LCC solution. Anyway the same feature will probably make it into the IQs at some point.
    Jan 2011
    Palo Alto, CA
    621
    Re: Crazy LCC idea
    Just a quick question: when you all do an LCC shot, do you open up a stop or two to try to get the histogram as centered as possible?
    Thanks,
    Bob
    May 2011
    San Francisco
    104
    Re: Crazy LCC idea
    Quote Originally Posted by rga View Post
    Thanks,
    Bob
    You learn from experience how many stops based on the situation. For example, lens is in shadow and subject is brightly lit, you may go 3 or 4 stops open. If bright light is directly entering the lens 1 or even 0 stop adjustment maybe the case. Exactly centered does not really matter as long as nothing is blown.
    Los Altos, CA
    10,486
    1031
    Re: Crazy LCC idea
    Thanks,
    Bob
    Yes. But to be perfectly clear, I open up by two SHUTTER speeds, not lens aperture, so as both the capture and LCC are at the same aperture. I am of the belief aperture affects LCC, and so why I never bought into the "standard set" concept. Second, note than in some situations you do not need to open up to get a centered LCC -- so it is important to look at your LCC histo.
  19. #19
    London, UK
    1,168
    38
    Re: Crazy LCC idea
    You create the files, load them to your CF card(s) and then in the field you select them much like selecting WB or color space when setting the shot. From there the raw files are created cast and falloff free. You do not need to apply anything and can skip the whole LCC post work
    That's a big step forward. Of course we would rather prefer to do away with the whole thing but with most LF lenses there's no escape...
  20. #20
    Jan 2011
    Palo Alto, CA
    621
    Re: Crazy LCC idea
    Of course; aperture remains constant.
    Rather than shooting a LCC exposure after each shot, if stitching I think shooting all the to-be-stitched images first, then shooting the associated LCCs afterwards would be preferable. The less time between stitched shots, the less change in clouds, etc... Only applicable to landscapes I guess, but that's what I mostly shoot.
    Thanks for all the great suggestions everyone. VERY much appreciated.
    Bob
  21. #21
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    Re: Crazy LCC idea
    If the C1 engineers were really good, you could use the images your camera shifts to make a map of the entire image circle and then use that map to correct any image at any position--it is simply a matter of registering rasters, which could be done automatically if the cast vignetting is apparent in the image. You would have to map the image circle at different apertures, although a model could certainly be made to compensate for any aperture.
  22. #22
    Vancouver, WA
    5,802
    564
    Re: Crazy LCC idea
    Quote Originally Posted by wentbackward View Post
    I think Sandy might be surprised to find that he's a lady btw :-)
    I ported the CornerFix code over to a different Mac UI a few years ago and so I know this pretty well. Unfortunately it won't do what you want with LCC's for any shifted or de-centered images because of the way that it calculates the image brightness drop off and also color cast. Basically it examines the source image for the profile by calculating a color / brightness fix curve that radiates from the center of the image. This assumes a uniform color shift and vignette - not something you'll see with a shifted lens unless you determine a different offset center point. Also it won't do dust removal etc using this technique.
    Indeed you could! (see above).
  23. #23
    Vancouver, WA
    5,802
    564
    Re: Crazy LCC idea
    Bob
    I tend to shoot LCC's this way myself in order to minimize the shoot/adjust exposure/LCC/readjust exposure/shoot/adjust exposure/LCC/readjust exposure sequence because its easy to forget to readjust the exposure. I'll often go home with a few shots where I've forgotten to adjust the exposure back and so have to shoot the frame twice (1x idiot shot followed by the correct shot).
    For stitches I'll tend to shoot the desired image sequence and then shoot the LCC's afterwards.
    However, there is lot to be said for the muscle memory approach of shoot/LCC/shoot/LCC style. It's simple and easier to manage within C1 later as it becomes a mechanical process of pairing images with their adjustments.
  24. #24
    Jan 2011
    Palo Alto, CA
    621
    Re: Crazy LCC idea
    Of course there are many ways to train your muscle memory. I tend to shoot
    my series (usually bracketed w/ shutterspeed) and then shoot the LCC and Color Checker last. That way I know when I look at them in C1 the final 3 LCCs belong to the preceding series.
    Whatever works, as long as you can remember!!
  25. #25
    Oct 2010
    South Australia
    1,484
    Re: Crazy LCC idea
    Thought about this previously; you could use an LCC layered in Photoshop to achieve illumination even-ness and probably colour correction too, by judicious selection of transfer mode. Must try it one day.
  26. #26
    SCHWARZZEIT
    Re: Crazy LCC idea
    How do you handle LCCs on long exposures?
    If your exposure is already near the limit of what the back can do, e.g. 90s for the IQ180, would you still add an additional stop or two in exposure time for the LCC?
    -Dominique
  27. #27
    23,623
    2555
    Re: Crazy LCC idea
    How about strobes doing interiors or something. Can't add more power. You have to open up
  28. #28
    Prescott, Arizona
    4,492
    367
    Re: Crazy LCC idea
    That is when it is appropriate to fall back on a library of standard lccs that you have previously prepared.
    -bob
  29. #29
    23,623
    2555
    Re: Crazy LCC idea
    Seems so
  30. #30
    Oct 2009
    Copenhagen, Denmark
    42
    Re: Crazy LCC idea
    Unfortunately this is not as easy as it might seem. First of all, it is surprisingly difficult to find a shift from an LCC. It looks really simple, but when you try it, the accuracy is just not very good in many realistic scenarios.
    Heck, even lab conditions will drive you mad trying to get the accuracy you think *should* be in the data.
    Also, the LCC does not merely records what the lens does. It records the interaction between the LCC and the sensor, which is something quite different. An LCC can only be applied to images taken with the same camera, and there is a good reason that this is the case.
  31. #31
    Vancouver, WA
    5,802
    564
    Re: Crazy LCC idea
    Quote Originally Posted by EsbenHR View Post
    This would certainly make sense. The vignette/color model used in Cornerfix suffers from inaccuracy of the correction curve estimation (taken from averaging multiple samples from radials from the selected center of the image - which for a shift would be offset - and then doing an RGB curve fit from the points) and so was never 'perfect' at the best of times, although not bad.
    I hate how theory and practice never quite match up in the real world sometimes.
  32. #32
    May 2011
    Hong Kong
    691
    Re: Crazy LCC idea
    I think a library of good lcc's is not a bad approach. My biggest problem is that the light falling near the camera is often very different to the scene in front of me. And the best images always seem to be in rapidly changing conditions. I might be wrong, but i do think it actually takes quite a bit of reasonably clinical effort in controlled conditions to shoot a good profile.
    Graham, I have no idea why it was in my mind that a lady engineer built corner fix. A bit embarrassing
    Paul
  33. #33
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    Re: Crazy LCC idea
    Which is why I said you would make the LCC with your specific camera/lens combination. The software would just apply the LCC map you created. You really don't need to make an LCC for every shift position.
  34. #34
    Oct 2009
    Copenhagen, Denmark
    42
    Re: Crazy LCC idea
    You can capture some information that way, but not everything. A sensor is not sufficiently uniform over its entire area to ignore these effects. The differences are normally calibrated away, but with movements you really do need to calibrate the sensor differently across the sensor.
    It is, unfortunately, not generally possible to map a calibration from one part of the chip to another without sacrificing IQ.
  35. #35
    Dec 2010
    45
    Re: Crazy LCC idea
    Guy, opening to a wider aperture will give inaccurate LCC results, especially in the case where 2 full values more exposure are necessary.
    It's easy enough in the situation you are describing to pop off a portable strobe directly at the plex covering your lens. You'd need to calculate the exposure/distance to the lens of course, but many find this produces great results. If you typically shoot at F11, you'd could repeat this without a lot of fuss.
    Like Graham, I shoot the lenscast reference shots most of the time at the end of the sequence of shots for stitching. For outdoor work with light changing or clouds moving quickly across the scene, the frames for stitching need to be shot in a quick sequence for the best results and less post production headaches later on. So, having the LCC shots at the end works best for me.
    In the case of long exposures, I actually reverse the process and shoot the lenscast reference shots at the beginning of the shoot, knowing that the potential buildup of noise also does not produce a good LCC file. I get the best results keeping the ISO native to the digital back and keeping the LCC exposure under 1 second. In long exposure situations, the portable strobe method works great too. (Nikon SB-900 or similar)
    Lonna
  36. #36
    23,623
    2555
    Re: Crazy LCC idea
    Lonna was thinking the same thing just turn the lights towards the camera and go from there. Yes i shoot the LCC after I get the image as well. Just seems to make more sense.
    Great idea on the long exposures. Thanks
  37. #37
    London, UK
    1,168
    38
    Re: Crazy LCC idea
    OK I'll share:-)
    Shot it yesterday at the Jardins des Serres d’Auteuil in Paris
    Aptus-II 12R, Arca-Swiss Rm2d, SK 43mm, 10mm rise and 12.5mm shift in each direction at f8.3 and 100iso
    Stitched with C1's script
  38. #38
    Jan 2011
    Palo Alto, CA
    621
    Re: Crazy LCC idea
    OK I'll share:-)
    Wow!
    Showoff :-)
