Results 1 to 10 of 10
Thread: Non-Araca plates on Arca heads
    Senior Member GMB's Avatar
    Oct 2008
    Heart of Europe
    396
    I am about to purchase the Arca d4m. It comes with a Flipplock or a classic lock (i.e., a screw). In principle, I would prefer the Flipplock (which I understand is the same as the one for the Cube).
    The Arca sales person said that with the Flipplock one should only use Arca plates, and not Arca compatible plates (as for example the RRS L plate for the S2, which I have on order, or the Arca style plate from Camdapter that works with their handgip). He suggested that if I want to use other plates I should go with the classic lock for the d4m.
    Any thoughts by those who use the Cube or an Arca ball head with the Arca Flipplock?
    Georg
    Feb 2011
    Eads, Tennessee
    1,035
    Re: Non-Araca plates on Arca heads
    Georg,
    I have the Arca Fliplock and would like to point out that it is adjustable. It can be used with any plate. That said, I don't use it at all. I found the opening process to be clumsy and much prefer the classic lock (screw) which is what I use.
    Victor
    Sep 2009
    Ontario, Canada
    446
    Georg, the flip lock does not accept some other plates. For example, the Camadaptor plates can only be held with the lock adjusted dangerously far out. Two problems. There is very little thread holding the thing together and your camera could fall if it lets loose, and you have readjust the lock every time you change to a different kind of plate. The official Arca plates, for example, will be far too loose if the Camadaptor fits.
    I have ground down a Camadaptor plate to fit, sort of. PIA to do and looks awful but at least it works. I prefer the screw clamp to avoid all of this hassle.
    Member David Duffin's Avatar
    Feb 2011
    Calgary
    77
    Quote Originally Posted by cunim View Post
    I wonder if it's practical to remove the Arca flip lock from the top of the Cube and replace it with an RRS flip lock. As you say, the thread on the Arca could certainly use some more length, and removing the camera from the Cube is indeed a royal PITA.
    May 2009
    Marseille, FRANCE
    972
    Quote Originally Posted by David Duffin View Post
    i'm using arca monorail, so for me the RRS isn't an option, because with the new style "classic screw" from arca, you can fix the rail directly !
    otherwise, it seems possible to adapt the RRS stuff...
    like this... !
    http://diglloyd.com/diglloyd/blog-im...SwissCube.html
    Feb 2011
    Calgary
    77
    A reliable hybrid! I'm gonna do that !!
    Oct 2008
    Heart of Europe
    396
    Thanks to all for the advice. Went for the Arca classic lock. Should arrive soon.
    Jul 2011
    Western Canada
    16
    I took delivery of D4 with classic clamp a month ago. I was a bit concerned about going to screw clamp after 3 years of RRS lever clamp use, but it's really a non-issue. It takes me maybe 2 or 3 seconds longer to mount the camera now.
    I'm using RRS L bracket and can't see any real advantage in switching out the Arca clamp, except perhaps for a very slightly lower profile.
    I'm sure you're going to be very happy with your new D4m and classic clamp!
    Feb 2011
    Calgary
    77
    Here's my hybrid cube now, with RRS lever clamp. I'm happy too.
    Member Dan Ortego's Avatar
    Sep 2010
    52
    Hi Dave,
    Dang! This is exactly the photo I've been looking for as I've been planning to do the same config. Specifically, I've been looking to see the stand-off and overhang between the head and the tripod apex.
    Though this thread is a bit dated I still need to know which specific RRS model clamp you ordered. I already have the TVC-23 and the C-1 is on the way. I have a couple other additives in mind but I'll save those for when I post my own pic.
