Results 1 to 14 of 14
Thread: telephoto lens on Arca-Swiss RM3Di Camera Body
    Senior Member stngoldberg's Avatar
    Apr 2011
    newport, RI
    808
    12
    Does anyone have any experience with o lens longer than 150mm 0n the Arca-Swiss RM3Di Camera Body?
    Thank you in advance
    Stanley
    May 2009
    Marseille, FRANCE
    972
    Re: telephoto lens on Arca-Swiss RM3Di Camera Body
    you have to have it mount with a sort of box on the rear between the body and the sensor... otherwise the tube on the front would be too long and vignetting would be important !
    Member LonnaTucker's Avatar
    Dec 2010
    Phoenix, Arizona USA
    45
    Quote Originally Posted by stngoldberg View Post
    Stanley
    I have experience with a 150 on Rm3d. The results were very good.
    Arca-Swiss indicates it is possible to work with focal lengths up to 250mm on the R series cameras. As Archivue states, the Arca lens mounting includes an extender for the rear of the camera.
    Mar 2010
    Germany
    253
    Quote Originally Posted by archivue View Post
    Capture Integration shows an image (scroll down a bit)
    http://www.captureintegration.com/20...a-swiss-rm3di/
    Chris
    Aug 2010
    Gainesville, Georgia
    177
    21
    LonnaTucker: experiance using 150mm telephoto lens on Arca-Swiss Rm3di: Can you provide a little more information on your experience? What speciific lens were you using? What type images were you making...etc. Thanks. Charles
    Dec 2010
    45
    Quote Originally Posted by cs750 View Post
    Charles, I was out photographing during the Palm Springs Photo Festival last early April. One of the participants had a 150mm Apo-Sironar digital. It is a general purpose lens for landscape, architecture, etc with an extremely large image circle.
    For my personal work I favor the Schneider wides, but for commercial work I do utilize normal to telephoto lenses. I have a Contax system and use the 140mm and 120 Makro a lot commercially with a Leaf back. I think a 150mm would be useful depending on what you photograph, of course.
    The longest lens I had used previously on an Rm3d was the SK 72mm XL. I don't know what you shoot, but if you are backpacking gear, the 150mm mounting for Arca-Swiss R isn't heavy, it just takes up more room in a backpack. Hope that helps.
    Aug 2010
    177
    21
    Lonna, thanks. I am on an Arca-Swiss Rm3di waiting list, and am simply trying to inform myself on the telephoto and macro possibilities. Charles
    Apr 2011
    newport, RI
    808
    12
    Thank you Lonna and Charles
    Does anyone else have any experience with long lenses in Arca-Swiss-Rm3di?
    Has anyone used anything longer than 150mm?
    Stanley
    Terry's Avatar
    New York City
    6,955
    1145
    Nope interesting thread for me as I will probably end up with the 150mm before too long.
    Brooklyn
    4,043
    1253
    i've been diddling around with a 120 on my cambo. love the format but...did not consider how long 120mm is when setting focus. that lens has to hang out there, achieved by cambo by adding a backplane spacer. works great, but means you have to change the lens (duh) and also remove the back and fit in the spacer in between body and back
    May 2009
    Marseille, FRANCE
    972
    i believe that on the RM3D, the 90 is the longer lense usable without the back spacer !
    Oct 2008
    Munich
    876
    correct. The 90 still works without one.
    May 2011
    Hong Kong
    691
    I think the schneider 180T and 210T are the only current digital telephoto lenses, even then they are ever so slightly telephoto.
    Oct 2009
    128
    5
    Quote Originally Posted by Christopher View Post
    Actually, the 100mm from Schneider is also without back extension.
    The back extension keeps geometry correct so movements remain accurate and easy to use and there is less vignetting as extension diameter is larger than front tube.
    Also helps with balance on tripod.
