Results 1 to 2 of 2
Thread: Question re: H2 Ixpress CFH 22 on Rollei 6008?
    Member jdbfreeheel's Avatar
    Jul 2008
    SF Bay Area
    111
    Hi All,
    I have a quick question that I'm hoping someone here can answer; sorry if it's considered "amateur or obvious but I'm trying to get a hard confirmation.
    Can the Hasselblad H2 Ixpress 22mp CFH Digital Back be "reattached" to the Hasselblad Ixpress i-Adapter Kit for using Rollei 600X/AF Camera with Digital Back.
    The reason I ask is because the H2 Ixpress 22mp CFH digital back seems to not use an external battery but rather the battery in the grip of the H2. Or am I completely off here?
    Thanks,
    Josh
    8,498
    44
    Re: Question re: H2 Ixpress CFH 22 on Rollei 6008?
    Quote Originally Posted by jdbfreeheel View Post
    Hi All,
    Thanks,
    Josh
    Hi Josh, not an amateur question at all.
    All CFH backs are dedicated to their H mount cameras (that's what the "H" stands for) ... as opposed to Hasselblad CF backs which use a clip on battery, and a series of iAdapters for use on multiple other MF cameras.
    So, the answer is no, you cannot adapt a CFH back to a Rollei 6000.
    If your CFH back has "in" and "out" sync ports, it can be used on a technical camera (like a view camera, or ALPA, Horseman, etc. type camera) but needs to be tethered to a computer via the firewire ... no battery is required because the firewire connection provides the power.
    I'll post a photo of what the technical camera set up looks like so you can look at the CFH back and see if it has the correct connections to use a tech camera.
