Results 1 to 4 of 4
Thread: Why colors washed out ?
    Mar 2008
    337
    I'm still learning my Sinarback 54M.
    The back provides excellent resolution. Shadow details are brought out very well.
    The Saturation is set to 100% in CaptureShop 5.6.1.
    But the colors look washed out and had turned into a very unsaturated version of what I normally see by eyes.
    How to improve the colors?
    4,333
    Re: Why colors washed out ?
    Can you post a sample?
    don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    thsinar
    Dear Evgeny,
    I suspect that you are using the "linear" curve, in the "process" panel, under "curve". This curve affects the contrast, and the linear one is giving a flat contrast.
    Use any other available "default" curve (Standard 1, Standard 2 or Standard 3) by clicking the pull-down menu (click the "arrow" in the upper right corner in the "curve" plugin)or create your own contrast curve by changing the shape of it. Once you have found a curve that fits your taste, you can save it with the pull-down menu (click the "arrow" in the upper right corner in the "curve" plugin).
    Best regards,
    Thierry
    Quote Originally Posted by evgeny View Post
    Mar 2008
    337
    Thanks, I will try.
