Results 1 to 17 of 17
Thread: Leaf Aptus-II 8 lens crop factor?
    Jan 2011
    78
    Hi, I'm trying to find a table with lens crop factor for leaf digital backs, but for some reasons all this information is hidden from a user.
    Anyone knows the numbers? thanks
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Re: Leaf Aptus-II 8 lens crop factor?
    Aptus-II 8 uses a 43.9x32.9 sensor, this gives you lens factors of:
    1.28 on 645 bodies e.g. Mamiya 645DF
    1.44 on 6x6 bodies e.g Hasselblad 503CW
    1.63 on 6x7 bodies e.g Mamiya RZ
    2.96 on 4x5 cameras (with 4x5 lenses)
    Hope this helps
    Yair
    e: [email protected]m | m: +44(0)77 8992 8199 | yaya's blog
    Shelby Lewis
    Check this out: http://www.captureintegration.com/?s...gth+calculator
    Put the focal length in under your specific back/sensor size and it'll give the focal length equivalents across many formats. Very helpful to my "stuck in 35mm"mind.
    Sep 2010
    181
    Quote Originally Posted by yaya View Post
    Hope this helps
    Yair
    Isn´t that a bit misleading to distinguish different crop factors for medium format systems. The 80mm of the classic 6x6 should give the exact same angle of view (and crop factor in regard to the digital back´s sensor size) as does the 80mm lens of the 645 system. The factor only differs in respect to the original film format ratio.
    Or am I confusing something here?
    Oliver
    Vancouver, WA
    5,803
    564
    For the Leaf II 8/P40+ to get 35mm equivalents divide the actual lens focal length by 1.46. Or put another way it's a 1.3x (1.28x) crop compared to full frame 645 as Yair quoted.
    Oct 2010
    South Australia
    1,491
    The elephant in the room—as I see it—is the feasibility of comparing different aspect ratios (usually 35mm’s skinny 2:3 to squarer, larger formats). I always work from the short side of the frame, assuming a print sized at “normal” 3:4 and 4:5 ratios; 35mm frames are always cropped lengthwise to fit these dimensions.
    So if you want to compare, say, the Aptus-II 8 to 35mm full-frame, the multiplying factor (rounding up) from 35mm is 33/24 = 1.375 — the other direction is 24/33 = 0.73 (rounded).
    Oct 2010
    South Australia
    1,491
    Quote Originally Posted by fotolli View Post
    Oliver
    The lens’s image size,* DOF etc. will be the same on any camera at the same focus point, but the horizontal and vertical field of view covered will vary with the frame size. So an 80mm lens on a Mamiya 645 film camera will show a bit more subject than with a smaller digital sensor, such as the 33 x 44 Leaf mentioned (a tenth of a millimetre? Gimme a break!
    But put the same lens on a 35mm full-frame camera and it’s a long-focus lens (not necessarily a telephoto!).
    *By image size, I mean the scale of the image.
    Vancouver, WA
    5,803
    564
    It's based on the diagonal of the format. If you crop for equivalent aspect ratio then of course the diagonal changes and hence the equivalency factor for crop purposes.
    In all other aspects though an 80mm lens is an 80mm lens regardless of sensor size or format as far as optical characteristics are concerned.
    I would agree though that for strict format comparisons there's a little more to it than pure multiplication factors. After shooting 4:3 for a long time 3:2 always feels like an ungainly aspect ratio ... I'm still a sucker for the square format so that probably makes me a dinosaur.
    Oct 2010
    South Australia
    1,491
    Let’s face it, the 120 square format was perfect for LP cover shots! CDs too.
    I remember a long-ago client wanting a 35mm negative printed to 10" x 8", and becoming very stroppy when I mentioned that there would be white strips top and bottom if I didn’t trim the print to 6 and two-thirds inches. Nowadays it’s easy enough to distort the image.
    Hong Kong / Asia
    524
    Quote Originally Posted by strok View Post
    Size of sensor is known. Apart from laymen cams that is all that seems needed
    I suggest that best is to understand how to calculate for you to know exactly and visualize exactly compared to other format. At times I compare both for vertical and horizontal. How else to compare e.g. 617 to 645 format lens visions?????
    To calculate is very simple
    Here are two examples;
    (1) Compared to 645:
    44x33mm sensor vs. 56x41.5mm -> 56/44=1.27
    (Here I picked horizontal, does not matter, since both 44x33 and 56x41.5 is 4:3 proportion sensor)
    (2) Compared to 6x6:
    44x33 sensor vs. 56x56mm
    by width: 56/44=1.27
    by height: 56/33=1.70
    by diagonals:
    sqrt(56x56+56x56)=79
    sqrt(44x44+33x33)=55
    -> 79/55=1.44
    (Here I looked at all, since 6x6 is square and 44x33 is 4:3 proportion)
    Most important: What I actually calculate to compare is the equivalent lens focal. If I know I like the vision of e.g. an 80mm lens on 645 but want to know what equivalent I should use on the Aptus 8 sensor in order to achieve same view, thus 100mm x 44/56 = 63mm
    Whichever you use is up to you and exact how you wish to compare.
    London, UK
    1,168
    38
    Oliver
    Most of the questions I get are:"So if I get an Aptus-II 8 for my RZ what's my 50mm is going to be like?"
    If the question was about an H2 then the answer would be different, hence why I just give the FL factor
    Vancouver, WA
    5,803
    564
    Quote Originally Posted by Anders_HK View Post
    Btw, once you know how to calculate for diagonals it's trivial to calculate for shifts as well. For example, if you have a 44x33mm sensor and are able to use a 10mm shift or rise in each direction the you can calculate focal length equivalents for a 64x33mm, 44x53mm or even 64x53 for multi-axis shift for the stitched image.
    Jan 2011
    78
    thank you.
    Senior Member Thierry's Avatar
    Jun 2011
    Switzerland
    329
    Very important to keep in mind. Together with the "equivalent lens calculator" mentioned by Shelby, it makes it easy to have an overview how it works with the different film/sensor formats.
    Thierry
    ... though an 80mm lens is an 80mm lens regardless of sensor size or format as far as optical characteristics are concerned.
    Thierry Hagenauer
    [email protected]
    Vancouver, WA
    5,803
    564
    Thierry,
    Here's a shameless plug for the Alpa mother of all calculation spreadsheets that I use:
    http://www.alpa.ch/en/products/tools...alculator.html
    It's not as simple as the Capture Integration worksheet but if you use shifts, tilts, DoF calculations etc it's ALL here.
    Jun 2011
    Switzerland
    329
    Thanks Graham!
    Yes, I am using this table as well. Much more complete.
    Best regards
    Thierry
    Thierry,
    Thierry Hagenauer
    [email protected]
    Shelby Lewis
    Thierry,
    Wow! Thanks for sharing this... I hadn't seen it.
    Shelby
