Results 1 to 13 of 13
Thread: Article on Phase IQ 180 on german Photoscala.de
    Mar 2010
    Lindenberg im Allgäu
    1,294
    12
    Quite interesting review of the IQ180 written by Anders Uschold - who is a Optics and Digitalphoto testengineer/specialist here in Germany:
    http://photoscala.de/Artikel/TestPra...-von-Phase-One
    for those who need this in English - try the google translate-it´s sometimes funny reading but you will get the point.
    http://translate.google.de/translate...-von-Phase-One
    Interesting are his findings about dynamics.....
    Greetings from Munich
    Stefan
    Oct 2008
    Munich
    876
    Re: Article on Phase IQ 180 on german Photoscala.de
    Sorry, but this alonw kills the whole test "Hinweis: Die folgenden Aussagen und Auswertungen beziehen sich auf mit den Standardeinstellungen in Capture One 6 entwickelte JPEG-Fotos. Mit einer anderen Abstimmung in Capture One oder einem anderer RAW-Konverter können die Entwicklungs-Ergebnisse auch anders gewichtet ausfallen. Etwa: Weniger Rauschen, dafür aber auch weniger Auflösung."
    I says so much as the test was done by converting the files to JPG without any editing. Or one could say it is like throwing aways most of the data.
    Mar 2010
    1,294
    12
    Hi Christopher
    right, but he also writes that using these differing settings the resolution will go down - the standard settings are optimized for a maximum resolution.
    It´s a bit like a table cloth that does not completely cover the table, if you pull one corner to cover, the other one will get uncovered.
    Regards
    Stefan
    Oct 2008
    Munich
    876
    He is wrong. Resolution has very little to do with dynamic range. I can certainly keep the same Resolution in my IQ180 shots and optimize the DR a lot. I don't think the standard settings are optimized very well. Way to much sharpening lot's of DR wasted.
    Mar 2010
    1,294
    12
    Hi Christopher
    Sorry here you err completely. see wikipedias definition of optical resolution
    http://en.wikipedia.org/wiki/Optical_resolution
    which per se is also valid for a digital recording system of that information:
    Measuring optical resolution
    A variety of measurement systems are available, and use may depend upon the system being tested.
    Typical test charts for Contrast Transfer Function (CTF) consist of repeated bar patterns (see Discussion below). The limiting resolution is measured by determining the smallest group of bars, both vertically and horizontally, for which the correct number of bars can be seen. By calculating the contrast between the black and white areas at several different frequencies, however, points of the CTF can be determined with the contrast equation.
    where
    Cmax is the normalized value of the maximum (for example, the voltage or grey value of the white area)Cmin is the normalized value of the minimum (for example, the voltage or grey value of the black area) When the system can no longer resolve the bars, the black and white areas have the same value, so Contrast = 0. At very low spatial frequencies, Cmax = 1 and Cmin = 0 so Modulation = 1. Some modulation may be seen above the limiting resolution; these may be aliased and phase-reversed.
    When using other methods, including the interferogram, sinusoid, and the edge in the ISO 12233 target, it is possible to compute the entire MTF curve. The response to the edge is similar to a step response, and the Fourier Transform of the first difference of the step response yields the MTF.
    So contrast (which is another word for dynamic range if you want to call it like this) is used to measure resolution !
    What you mean is visual improvement of dynamic range , but this ALWAYS lowers resolution by using Imaging algorythms that take information from one part of the resolved data set to compute it into another visible information (which as 80MPix do have plenty of reserve - used with the right lenses - may not be visible at first).
    these transformations are also lossy - so there is no such thing as a free improvement in one area, most of the time you even cut off information
    (see Histogramm after applying Photoshop Gradation). This does not change if you do it in 16 Bit raw processing (C1), it´s only less obvious.
    Regards
    Stefan
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by Christopher View Post
    Die folgenden Aussagen und Auswertungen beziehen sich auf mit den Standardeinstellungen in Capture One 6 entwickelte JPEG-Fotos. Mit einer anderen Abstimmung in Capture One oder einem anderer RAW-Konverter können die Entwicklungs-Ergebnisse auch anders gewichtet ausfallen. . . .
    Or you could also say :
    Wenn der Hahn kräht auf dem Mist , ändert sich das Wetter , oder es bleibt wie es ist .
    I do love such statements .
    Regards . Jürgen .
    KEMPTEN / GERMANY
    1,513
    116
    Sorry for the german words , but I just could not resist .
    Regards . Jürgen .
    Senior Member Thierry's Avatar
    Jun 2011
    Switzerland
    329
    At least there are a few here understanding it!
    Thierry
    Thierry Hagenauer
    [email protected]
    23,623
    2555
    I think it reads Guys gets a free Alpa STC.
    www.guymancusophotography.com
    23,623
    2555
    OT but I'll ask anyway Thierry does Alpa still make the SWA
    Mar 2010
    1,294
    12
    Hallo Jürgen
    Passt schon......... - Stimmt aber nicht.
    It´s OK - but it doesn´t fit.
    To save a file in JPG does not mean you are losing any visible information against a Tiff especially if you take into account that in reality digital camera chips are only taking/processing/reaching about 6 bit of data for distinguishable steps of signal processing.It is lossy but JPEG is by far good enough to represent this on a monitor or a print.
    So what would have been different if Anders Uschold would have saved the files to Tif ? Nothing. His statements will nevertheless stay valid.
    Grüße aus München
    Stefan
    Jun 2011
    Switzerland
    329
    Guy, as soon as it is about new gear, you could understand any language!
    Yes, the SWA is still produced:
    Alpa 12 SWA
    Best
    Thierry
    Thierry Hagenauer
    [email protected]
    23,623
    2555
    LOL. You got that right. Thanks was not sure if the STC actually replaced it or just a addition to the line.
