Results 1 to 5 of 5
Thread: Plaubel Makina 670 Frame Spacing?
    Sep 2010
    Sausalito, CA
    99
    I just processed a roll out of my new Plaubel Makina 670 and the frame spacing is uneven. The spacing seems to be random, sometimes 1/4" and sometimes 3/8" .
    I know this is supposed to be an indicator of a future repair, but how soon?
    Any ideas?
    Bob
    May 2009
    Marseille, FRANCE
    972
    Re: Plaubel Makina 670 Frame Spacing?
    once, i had a same problem (with a 500 CM), and as you, i was waiting... till i've lost a very good and important shot ( at least for me... ) , because of frame overlaping...
    Feb 2009
    1,083
    6
    I do have this issue more than once on different film bodies [all MF], so i have to see what's wrong.
    Tareq
    7
    I have just taken my Plaubel Makina 670 to the UK agent for a light leak problem (from my sample negs replacement door seal - Phew and nothing
    worse hopefully) I also pointed out an uneveness in the spacing.
    Apparently this typically happens at the fifth frame?
    Anyway,the good news is that you can,according to him, fix it yourself!
    I will double check this info. when I see him to pickup the camera,but it is
    all a matter of retentioning a spring as you load a film.
    Lets say you have got to the stage of attaching the film to the take up spool and about to wind on to the marker on the backing paper before closing
    the camera back.
    Before you do this,place the thumb of your left hand on the backing paper
    on the take up spool to create tension and start to wind on. Just above the top of the take up spool you can see a spring which as you wind on will retention and solve you spacing issue.
    I hope you find this info. useful. I will try and confirm any variation to the
    above,when I next have contact with the UK agent.
    Please do not rely on it if you are about to take an important sequence of
    shots;maybe try the procedure and run a test film to see if it worked.
    All the best,Ivan.
    Sep 2010
    Sausalito, CA
    99
    Thanks for the responses! I loaded a roll a few minutes ago and made sure it was tight, someone on pnet mentioned mentioned this may take care of it.
    Ivan, If you get any more information from your repair guy please post it here, I will try the method you mentioned when I load the camera tomorrow.
    Bob
