Page 3 of 3 FirstFirst 1 2 3
Results 101 to 102 of 102
Thread: D4 vs Cube
  1. #101
    KEMPTEN / GERMANY
    1,513
    116
    Re: D4 vs Cube
    Exactly how I use my CUBE and D4 as well .
    Regards . Jürgen .
  2. #102
    Aug 2008
    Carmel/Tucson
    2,355
    Re: D4 vs Cube
    Quote Originally Posted by satybhat View Post
    Does anyone know Which of the two RRS clamps fits the cube ?
    the B2-40LR 1/4"-20 , or the B2-40LR with the M6 clamp ?
    Saty,
    I don't recall the RRS clamp number, but RRS should be able to direct you here----or someone will chime in shortly.
    BUT be aware that newer Cubes (stupidly imo) apparently use the strong version of loctite on the stock Arca Cube clamp, making it very difficult to remove. A directed heat gun and great care is required to remove the arca clamp in order to replace it with a RRS screw or RRS flip lock clamp.
    Luckily for me I have one of the older (hence more desireable ) Cubes and can swap clamps easily. I've gone from stock arca cube clamp, to RRS screw clamp, and now back to the stock arca cube clamp... I'll probably end up with a RRS flip clamp with the CI in Carmel tour at the RRS facility in Feb 2014!
    ken
