Results 1 to 19 of 19
Thread: Body cap for Arca Swiss RM3di
    Jul 2011
    Tasmania
    85
    13
    What do RM3di owners do to protect the camera interior and the sensor when the body is stored/transported without a lens in place? I don't believe that an AS body cap exists but would be happy to be corrected on this.
    Any suggestions welcome!
    Rob
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: Body cap for Arca Swiss RM3di
    A large zip-lock plastic bag.
    -bob
    May 2009
    Marseille, FRANCE
    972
    i use my little 35 XL ;-)
    Los Altos, CA
    10,486
    1031
    I use whatever lens that happens to be on it when I put it in the bag. Of course this requires that you have a bag that fits your camera with a lens mounted
    home: www.getdpi.com
    Jul 2011
    Tasmania
    85
    13
    I'm trying to fit everything into a slim bag, hence the need to detach the lens. Just now ordered a 110mm Schneider lens cap which might just do the trick.
    Member JonMo's Avatar
    Mar 2011
    Delta BC Canada
    100
    8
    With my Cambo Leaf combination I leave the lens attached with the front and back caps on and protect the back with it's steel plate while using the slim bag.
    Is it easier on the RM to leave the back attached and not the lens?
    May 2009
    Marseille, FRANCE
    972
    no
    Oct 2009
    128
    5
    The problem with a cap is that one needs to be careful it doesn't scrub the number scale on the outside of the helical focus ring. A 90mm cap drops in. A 100mm doesn't fit. A 105mm may work, but I still worry about the numbers being scrubbed...
    I am thinking about the issue, though.
    Bag wise the Crumpler Celibrity C-list medium is great. Deep enough to leave the back and lens on the camera through about 72mm. Never a 32mm or 28mm Rodenstock.
    Just a bit of pressure can mess up alignment. Also the 43mm and 28mm Schneiders. The large fronts on these lenses create leverage on the edge of lens which may impact the shutter and decenter the lens. This is the primary reason for loss in sharpness on one side or top or bottom of images.
    Prescott, Arizona
    4,492
    367
    It might be possible to order a lens board with no hole and them fit a small cabinet handle to it.
    -bob
    Santa Monica, CA
    2,272
    2
    If you can accurately measure what you need, SKGrimes can likely make it.
    I've bought custom lens caps from them, and the second in a given size is much cheaper than the first, so if a few people want the same item, it would probably be inexpensive.
    May 2009
    Marseille, FRANCE
    972
    Quote Originally Posted by Bob View Post
    -bob
    i'm not shure that they sell lens board alone...
    Los Altos, CA
    10,486
    1031
    FWIW, a threaded 95mm flush-fitting lens cap -- meaning the kind you squeeze from the center as opposed to tabs on the edges to operate -- fits inside the A/S lens mount like a glove
    Santa Monica, CA
    2,272
    2
    Member LonnaTucker's Avatar
    Dec 2010
    Phoenix, Arizona USA
    45
    Quote Originally Posted by stephengilbert View Post
    Good find, I want one!
    Los Altos, CA
    10,486
    1031
    I have a generic, and not sure the Hassy cap is all internal, but if it is it should work fine too!
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Stepehen,
    Just tried one of these caps with our demo R3MDi and it physically fits, but does not stay on because the clips to not extend out far enough.
    Lance
    LANCE SCHAD - Digital Transitions - Phase One,Mamiya | Leaf,Arca-Swiss,Cambo, Profoto
    direct/cell:610-496-5586 office:877-367-8537x224
    http://www.digitaltransitions.com email:[email protected]
    Los Altos, CA
    10,486
    1031
    On my generic, the cap's threads extend enough to grip the lensmount threads in the body. To be clear this is not a zero-clearance fit, so while it certainly protects the innards it is not going to be 100% dust-proof.
    Jul 2011
    Tasmania
    85
    13
    I can happily report that the $29 Schneider 110mm Push-On Lens Cap fits beautifully as a body cap for the RM3di. Snug, and I'll keep a watch that the numbers on the helical focus ring aren't being scrubbed, but perfect. Would be an effective barrier to dust.
    Rob
  19. #19
    May 2009
    Marseille, FRANCE
    972
    i'd like to tried that solution...
    http://www.arca-shop.de/Cameras/R-Li...3_131_179.html
