Results 1 to 14 of 14
Thread: replacing flip lock on as cube
    Sep 2009
    Ontario, Canada
    446
    I believe this has come up before but can't find the specifics.
    The flip-lock on my AS cube is driving me nuts as I go from one make of plate to another. I much prefer the AS screw clamp that I use on the studio stand. Can anyone tell me exactly what AS part I need to order to replace the flip-lock on the cube with a screw clamp? I need to use the clamp with both standard AS plates, and the base rail of a Monolith system.
    Vancouver, WA
    5,802
    564
    Re: replacing flip lock on as cube
    The AS 802015N will fit both the new Slidefix & traditional AS/RRS plates and L brackets.
    http://rodklukas.com/resources/ClassicQuickFix.pdf
    http://www.arca-shop.de/Monoballs/Ac...ball::921.html
    Santa Monica, CA
    2,274
    2
    What a guy: 17 minutes, with links.
    Mar 2010
    Germany
    253
    Alternatively, you can use the RRS clamp (I just replaced my AS clamp with this one). Here's a description:
    http://diglloyd.com/articles/Recomme...SwissCube.html
    A minor drawback of the RRS-clamp: The screw takes a lot of space - see attached picture (sorry, it's a quick iphone shot) - it sticks out, close to 1 in.
    Chris
    Senior Member Joe Colson's Avatar
    Oct 2010
    North Carolina, USA
    1,911
    36
    Since we're all (except Graham) offering alternatives to what you really want, let me throw in another. I use the RRS lever clamps on all my tripods, monopods and gimbal mounts. It's the B2 AS II clamp with M6 screw. And although digilloyd.com doesn't recommend it, I've never had a problem in the field. It's works like a charm. Here's the link:
    http://reallyrightstuff.com/ProductD...6-screw&key=it
    The good news is that there are multiple solutions/alternatives.
    Joe
    _________________________________
    Joe Colson Photography
    Brooklyn
    4,043
    1253
    i use the RRS screw clamp and find it very secure. The large knob is a bonus so you don't turn it my mistake
    23,623
    2555
    It's the Pano clamp that I threw over the wall. Almost lost my whole rig three times off my tripod carrying it. Reason I have a strap too.
    www.guymancusophotography.com
    May 2009
    Marseille, FRANCE
    972
    "The AS 802015N will fit both the new Slidefix & traditional AS/RRS plates and L brackets."
    and even more...
    i went with that one because it also fits Arca camera's rail directly !
    So, i'm using a camera rail even with my RM3D if i need to set the nodal point, or if i need to have the camera close to the wall...
    Los Altos, CA
    10,486
    1031
    Couple of points:
    1) Older Cubes do not accept the newest A/S dual dovetail clamp properly, you need an entire top panning assembly -- be forewarned!
    2) RRS lever clamps are not adjustable and will NOT close tight enough to clamp an original A/S plate or other non-RRS plates; RRS plates are slightly larger dovetail standard, ostensibly to avoid any patent issues with A/S.
    home: www.getdpi.com
    Jun 2009
    17
    Once I discovered the phase 2 lock on the original A-S flip-lock and got the adjustment right, I found it to be arguably better than any of the alternatives. Mine now works fine (i.e., securely) both with a small A-S mount (as on the Rm3di) and with various "A-S compatible" plates. I'm considering replacing some other clamps, as Guy did.
    Dave.
    Oct 2010
    North Carolina, USA
    1,911
    36
    That's why I use RRS L-plates on my Nikon and 645DF and a Kirk PZ-130 on my ALPA STC. With an RRS lever clamp retrofitted onto the Cube, the mount is solid and secure. Since I was already in the RRS camp, with a BH-55 ballhead and an RRS lever clamp on a couple of Wimberley gimbals, it was easier to stick with RRS than switch to another standard.
    Joe
    23,623
    2555
    Yea i agree once you decide to go one brand stick to the brand for all your cams. Especially with the lever locks. I went completely Arca plates. Since I use the lever clamp the slidefix and the regular Arca plates work perfectly in my Arca lever clamp. For Phase shooters the Arca plates do have one just for your AFD or DF camera plate.
    For those that don't want a lever lock the make the same clamp in a screw down version and you can use the slide fix and regular Arca plates as well.
    Sep 2009
    Ontario, Canada
    446
    Thanks for the comments. Guess I will order the AS screw clamp. Jack, my cube is about year old so I hope the current clamp will fit. I'll try to check before ordering.
    I agree with sticking with a single make of plate. My problem arose because I really need a hand strap for the DF body, and no one seems to have an AS plate + hand strap gizmo that fits. That put a Camadaptor plate into my system and troubles started there.
    Actually, I find the screw clamp easier to use so looks like a win-win.
    Apr 2009
    Sydney, Australia
    581
    2
    One thing that I hate on the Arca clamps is that they can unscrew leaving you with the bits in your hand, if you are lucky. I was adjusting mine in the boonies of Iceland and just caught it in time. That was a tense moment - the start of a week and almost losing your tripod on day one.
    How can such a beautiful piece of engineering have such a dumb feature? It's even better than the 'not level' levels.
    Jeff
    www.jeff-grant.com
