Page 14 of 14 FirstFirst ... 4 12 13 14
Results 651 to 662 of 662
Thread: Show us your Tech Cam
  1. #651
    Senior Member danlindberg's Avatar
    Aug 2010
    Spain & Sweden
    1,196
    Re: Show us your Tech Cam
    Quote Originally Posted by jagsiva View Post
    Dan, that looks like the first useable hood I've seen for the 32HR. Looked on the Alpa site and could not find it. Do you have a part number or model number?
    Cheers...
    Just to let you know that they are all up now on the website!
    https://www.alpa.ch/en/artikel/lens-shade-hr32-type-d0
    Alpa FPS • MAX • TC | Alpagon 32Hr | Helvetar 75 | Schneider 120N | Leaf Aptus II 5 • Leaf Credo 60 | www.danlindberg.com
  2. #652
    Nov 2015
    Sweden
    6
    Hi!
    Here are some new images of my current setup with my old and trusty Hasselblad H3DII-50 and info how I power it with an external battery.
    Thanks to "torger" for tip about the adapter.
    I put the Camera-Settings-Body to "Flash Sync". For longer shutter speeds I use T mode on lens on press once to open shutter and once again to close it.
    Battery 8000mAh from Dynamic Perception fastened with a DuoTech strip.
    http://www.dynamicperception.com/Por...-p/dp-ppb1.htm
    DC to Firewire 800 adaptor (Need to cut som plastic off the side to fit)
    http://www.mamiyaleaf.com/accessorie...tal_backs.html
    Attached Images Attached Images
  3. #653
    Senior Member JohnBrew's Avatar
    Jun 2013
    South Carolina
    532
    Nice setup . I'm curious when compared to CFV-50c if heavier and if battery life is improved.
  4. #654
    Nov 2015
    Sweden
    6
    My back with this battery is about 900g vs the CFV50c with battery that weights approximately 650g.
    My battery last very long (8000MAh). During a winter day shooting landscapes in -10degrees Celsius it lasted almost from morning to evening.
    During a normal day it΄s not even half emty after a day shooting landscapes. I also use the H camera system, otherwise I think the CFV50c is a smoother solution.
    /Stefan
    Quote Originally Posted by JohnBrew View Post
  5. #655
    Sep 2011
    1,069
    83
    Quote Originally Posted by danlindberg View Post
    Thanks Dan. Any thoughts on performance with movements?
  6. #656
    Dec 2012
    France
    193
    Post Re: Show us your Tech Cam
    Just a heads up to let you know that the Arca-Swiss R-mount Canon adapter kit (ref 017019) is available and shipping.
    It consists of 2 parts : an adapter plate on the front to mount the Canon lens board on R-line cameras, a spacer (here's on the rear of the factum) which is the width of the yet to be released A-S focal shutter.
    Click image for larger version.
  7. #657
    Mar 2017
    Modena, Italy
    3
    Italian Excellence, German Precision and Swedish Quality
    Digital eq.: Silvestri Bicam III, sk35mm apo-digitar and sk90mm apo-digitar, Hasselblad cfv-50c
    Analog eq.: Silvestri Bicam III, sk47XL and sk72, 6x7, 6x9 and 6x12 horseman back
  8. #658
    Jul 2013
    31
    Quote Originally Posted by andrearch View Post
    nice, have the same setup, with an IQ160, but less lenses
  9. #659
    Jan 2017
    94
    Got it home safely.
    As you can see, it rather dwarfs everything else!
    I am a Dalek! Destroooooy!
  10. #660
    Aug 2010
    Spain & Sweden
    1,196
  11. #661
    May 2012
    2,057
    This is the coolest shade I have ever used Weighs close to nothing, just slide it on and off in a second (yet snug and safe fit). Excellent result with a little higher contrast even with lightsource behind you, realising that straylight effects the Rodie 32 more than I thought. Flagging really isn't enough for that particular lens. Highly recommended for 32 owners.
    Thanks to you I now have this same type of lens hood for my 40HR and 70HR. They weigh nothing and can be folded if need be without damage.
  12. #662
    Senior Member stngoldberg's Avatar
    Apr 2011
    newport, RI
    807
    12
    Dan,
    Does the lens shade for the Rodie 32 fit over the center filter?
    Stanley
