Page 9 of 14 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 401 to 450 of 662
Thread: Show us your Tech Cam
  1. #401
    Senior Member danlindberg's Avatar
    Aug 2010
    Spain & Sweden
    1,196
    Re: Show us your Tech Cam
    Alpa FPS • MAX • TC | Alpagon 32Hr | Helvetar 75 | Schneider 120N | Leaf Aptus II 5 • Leaf Credo 60 | www.danlindberg.com
    Likes 10 Member(s) liked this post
  2. #402
    Senior Member thrice's Avatar
    Aug 2009
    1,265
    Wow Dan! That looks like a lot of fun to shoot.
  3. #403
    Jun 2008
    SoCal
    291
    15
    Very cool Dan!, what is the blue band for?
    Cheers, -Peter
  4. #404
    Vancouver, WA
    5,802
    564
    Quote Originally Posted by PeterL View Post
    Cheers, -Peter
    Peter,
    The edge of the IQ and Credo backs tend to rest on whatever surface you put the camera down on. It's liable to scratches over time in my experience. I've been thinking about doing something similar (I've used gaffer tape) after my own back got a few marks on it. On the Credo it can also prevent hitting the on/off switch ...
    Dan, make sure that you lock that release button
  5. #405
    Jun 2008
    SoCal
    291
    15
    Ah - I see, thanks Graham. I usually don't put it down on a surface, the IQ and 35XL goes direct from bag to tripod, but I see what you mean.
    Cheers, -Peter
  6. #406
    Jan 2012
    1,198
    Took me a couple of minutes to work it out, since the tripod plate mount looked odd.
    But of course it's because you're using the TC rather than the 11mm adpater
    No fewer than 6 interfaces between lens and back there!
  7. #407
    Vancouver, WA
    5,802
    564
    Gerald/Dan,
    You folks are doing nothing to diminish my FPS lust Only my pent up IQ260 lust is stronger right now
  8. #408
    Aug 2010
    Spain & Sweden
    1,196
    Thanks guys I do not think I have ever used any type of camera that inspires more for experimentation and think-outside-the-box setups.
    Graham is spot on regarding the rubberband. It acts as a cornerprotection and with small techlenses it dips backwards when put on a table and then the back rests on the rubber. I am extremely careful with my gear, still have the original sheet of plastic protection for the display! The ON button is easy to push by mistake and with the rubberband this is less of a problem.
    The cool thing of using Hassy lenses is that I can have simultaneous shift and tilt/swing. On these pictures I use the TC and tilt adaptor but could ofcourse used the SWA or even the MAX instead.
    I have only just seen the first images from the Distagon 4/40 IF, but the result is not bad. Not bad at all.....
  9. #409
    Aug 2010
    Spain & Sweden
    1,196
    I see it wasn't locked on the picture, but in this case no worries. I use my older DB adaptor to shim the back for perfect infinity with the Distagon and that adaptor is a very very tight fit. Tough to take off. However, locking is never a bad thing...
  10. #410
    Jan 2012
    1,198
    I wonder if ALPA will start doing HPF rings for these alternative wide angles?
  11. #411
    Melbourne, Australia
    2,338
    52
    Dan - please talk me into this new alpa gizmo - tell us all what you like about it and how you think you might use it.
    Pete
  12. #412
    Aug 2010
    Spain & Sweden
    1,196
    Quote Originally Posted by PeterA View Post
    Pete
    Pete, its a must have!
    I have only just started to use it, so I will avoid any in depth analysis. However, as a first and initial impression it is OUTSTANDING. I have been used to the classical Alpas for quite some time and the Schneider tech lenses, thus, the FPS and non-tech lenses will have a tough game to play.
    Right now I am trying out my Hassy V lenses and the Distagon 4/40 IF is up there in resolution. Haven't done distortion tests yet, but it will be a landscape lens anyway.
    The Schneider PC-TS 90 is razorsharp and it really is handy to have all the movements right there in the lens.
    I could actually see myself with a two lens setup in the future - PC-TS 28 + PC-TS 90 + FPS + CREDO 60 and call it a day. I could probably do 85% of my work with these two lenses and for the rest - I could have a beer instead
    I am only beginning to explore the FPS but the feel is tremendous and the possibilities endless.
    If you try one - you buy one!
  13. #413
    Vancouver, WA
    5,802
    564
    When I briefly tried one, my most memorable highlight was the incredible smoothness of the shutter. Given that its a Mamiya shutter that impressed me.
    It's built like its made of pure unobtanium - incredibly solid feeling and I personally drank the downloadable firmware update potential kool aid. They've designed this camera for flexibility and with future proof approach.
  14. #414
    NYC
    3,275
    7
    On a slightly different note here is a video of our Cambo RC400 demo unit set to the music of Flight of the Bumblebee:
    https://vimeo.com/63916039
    Cambo Tech Camera Product Page
  15. #415
    Nov 2008
    Chicago
    550
    Thats a fast moving camera with a great sense of humor. Nice.
  16. #416
    Aug 2012
    1,114
    Dough, what viewfinder / eyecup is that in the video?
    Peter
  17. #417
    NYC
    3,275
    7
    Quote Originally Posted by Pemihan View Post
    Peter
    The current Cambo viewfinder and the Cambo iPhone adapter take turns being on top.
    Older Cambo viewfinders lacked the eyecup which is on the current version.
  18. #418
    Aug 2012
    1,114
    Thanks Dough.. Do you know if the eyecup will fit the older viewfinder?
    Peter
  19. #419
    Jul 2010
    655
    Endless possibilities
  20. #420
    Mar 2010
    Southampton
    565
    Well, Alpa has a reputation for burning a hole in your wallet - now I see why
  21. #421
    Mar 2010
    Southampton
    565
    Wow, could you imagine the size / cost of some of those! Since focus scales on Canon, Nikon, Hasselblad etc. lenses are not as accurately marked as HPF rings, if you want to focus accurately I guess you have to shoot/review/tweak/shoot/review/tweak etc. (assuming you're using a DB with a good screen) or remove the DB and attach the Alpa ground glass?
  22. #422
    NYC
    3,275
    7
    Peter
    We think so, but don't have an older one to test.
  23. #423
    314
    Quote Originally Posted by danlindberg View Post
    ...The Schneider PC-TS 90 is razorsharp and it really is handy to have all the movements right there in the lens.
    I could actually see myself with a two lens setup in the future - PC-TS 28 + PC-TS 90 + FPS + CREDO 60 and call it a day. I could probably do 85% of my work with these two lenses...
    Does anyone know delivery date and cost of TS 28mm,
    and how good it is (their TS 50mm isn't highly regarded, correct?)
  24. #424
    Nov 2010
    Munich/Guangzhou
    138
    Dan, if you would mount the Hasselblad 40 with a Mirex Hasselblad V - Canon EF TS adapter on a Canon mount to the Alpa FPS, you would get +/- 16mm shift and tilt with that lens (and any other V lens).
  25. #425
    Jan 2012
    1,198
    Quote Originally Posted by chrismuc View Post
    No need to use the Canon adapter Chris, keep it all ALPA
    FPS + Max + 17mm T/S adapter + the Hasselblad V mount adapter would do the trick.
    (Basically, the set-up Dan has in his photos at the top of this page, but with the Max in place of the TC)
  26. #426
    Aug 2010
    Spain & Sweden
    1,196
    Chris, it's like Gerald explained. The Hassi V lenses have both the tilt/swing adaptor + traditional Alpa body mounted on the FPS. So I have the choice to keep it as small as possible with the TC or full movements with the MAX.
    I have only just started to try shifts with the Distagon 40 IF, but it seems like 10mm shift on the long side is perfectly alright and usable - after that it gradually starts to soften up and vignette. Overall the IF is pretty impressive even with the mighty 60mp back.
  27. #427
    Nov 2010
    Munich/Guangzhou
    138
    Thx Dan and Gerald, ooookay, I see, I did not know that it would be possible to combine Hassi V lenses + Alpa TS adapter + Alpa cam + Alpa FPS.
    But I plan to visit Alpa CH end of May to test the FPS with the IQ180 and my EF mount based shift lenses (Canon 17TSE, 24TSE, Contax 35 + Mirex EF, HB 50FLE + Mirex EF, HB 100 + Mirex EF). Looking forward to discover that new tool/toy.
    Btw, would be very interesting to compare the shifted corner quality of the Contax 35 and the Hassi V CFE 40 IF but I don't have one on hand (only the CF 40 FLE / CFE 40 which is not so impressive).
    Chris
  28. #428
    Aug 2010
    Spain & Sweden
    1,196
    Chris
    I am happy with the resolving power from the Distagon 40 IF. The non-IF FLE and CFE are not up there. However, this resolution comes at a price - more distortion. In the image below you can clearly see how the horizon distorts. On a side note, the placement of the camera is more extreme than it looks. It is only around 35-40cm above ground and I have full 5 degrees forward tilt. The original file shows impressive detail and sharpness.
    It will be interesting with your findings matching the FPS with your lenses!
  29. #429
    KEMPTEN / GERMANY
    1,513
    116
    Dan
    I have the DISTAGON 40 IF as well and find it to be an outstanding lens .
    Unfortunately I can only use that lens with my V-SYSTEM bodies .
    As I use HASSELBLAD CFV backs , I can use the lens correction function in PHOCUS . I don't know , if this function is available for P1 or LEAF files .
    Might be that ALPA comes up with some new lens corrections for the mostly used lenses with the FPS .
    Regards . Jürgen .
  30. #430
    Senior Member rayyen's Avatar
    May 2011
    Hong Kong
    608
    My Max & SK47XL
    Leica | Angenieux | Alpa | Hasselblad | Phase One
    www.raymondchak.com
  31. #431
    KEMPTEN / GERMANY
    1,513
    116
    Quote Originally Posted by shortpballer View Post
    Is this the shutter burning after a 1000 exposures ? ? ?
    If so , ALPA should design a "shutter cooling device" (SCD)
    Regards . Jürgen .
  32. #432
    Jul 2010
    655
    From what I've heard the shutter lasts longer than most camera shutters out there... well over 300k. Not cooling device necessary
  33. #433
    Apr 2013
    83
    Question Re: Show us your Tech Cam
    is this tech Cam?
  34. #434
    Jul 2010
    655
  35. #435
    Vancouver, WA
    5,802
    564
    I had a chance to try out the Arca Swiss RM3D and eModule Cloud solution this weekend along with an IQ260 prototype.
    I found it very interesting and couldn't keep my eyes off it
  36. #436
    Mar 2010
    Germany
    253
    ... along with an IQ260 prototype.
    Why don't you want to talk about it? :-)
    Chris
  37. #437
    Vancouver, WA
    5,802
    564
    Quote Originally Posted by cly View Post
    Chris
    I was in lust ... and I quite liked the Arca and IQ back too.
    None of them were mine unfortunately and I was just trying them out for the weekend. The girl was a very scenic photobomb while I was shooting long exposures around the Lincoln Memorial in Washington DC. No trace of her remained in the 30 minute exposures
    Btw, the eCloud module seems like it works once you've calibrated it for infinity. I'm not tempted away from my Alpa and Distometer but it was interesting to try something different. The glass is all the same after all.
    I preferred my crop of the scene above but here's the reality:
  38. #438
    Shashin's Avatar
    May 2011
    Florida, USA
    4,500
    141
    A little disappointing the chick is posing for the guy with the iPhone. You spend all that money on the ultimate babe magnet and the guy with the Fort Escort beats you to the punch. Maybe it is because you forgot your Cube. The P series heads are great, but are not as magnetic.
  39. #439
    2,338
    52
    Hi Dan,
    I am rather busy with building my farm house at the moment so don't check in much. Thank you for your reply. I have decided to 'take the plunge' and buy my version of an elephant gun back an IQ260 in Mamiya mount for use with my tech camera gear.
    The FPS looks perfect for me because I can use a variety of lenses with and without movement ...keep us posted on the stuff you end up doing. I wonder how you go about 'framing' the shot you intend to make using the FPS?
    All the best
    Pete
  40. #440
    Pratamnak
    9,344
    2157
    Quote Originally Posted by Sunchai View Post
    is this tech Cam?
    This looks very cool, but who makes it, what does it cost, what is the lens mount and does it work as it's supposed to?
  41. #441
    Apr 2013
    83
    Talking Re: Show us your Tech Cam
    Quote Originally Posted by Jorgen Udvang View Post
    More info. Have posted at “Phase One Hybrid”
    And it is my interesting to see dead to be alive.
    Sunchai
    Attached Images Attached Images
  42. #442
    Jun 2010
    Switzerland
    53
    Love mine :-)
    Horseman SW-D II Pro
    Lee 100 mm Filter + 105 mm Pol Filter attached
    Kapture One "one shot cable release"
    Phase One P45+
    An old Berlebach wooden tripod
    Manfrotto 410 gear head
    visit me at www.kabraxis.de or http://www.flickr.com/photos/kabraxis/
    My ebay stuff
  43. #443
    Apr 2013
    83
    Smile Re: Show us your Tech Cam
    is this tech CamII
  44. #444
    Jun 2010
    Switzerland
    53
    is this tech CamII
    Uhhh nice,.. were do you get this stiching back plate?
    greetings
  45. #445
    Apr 2013
    83
    Thank you for this personal message.
    "Cool camera setup, may i ask what camera and stitching back this is"
    if it may be interest to other.
    the camera is Mamiya RB67 Pro SD with the shifting adapter.
    I have named it RB shifting adapter it was designed since Phase One
    light Phase back in 1990-2000 as I can remember.
    it is directly mounted to the RB camera with infinity focusing on the normal
    viewfinder.
    Shifting left and right 20mm.
    Shifting up and dowd 18mm.
    Sunchai.
  46. #446
    Apr 2012
    Hong Kong
    509
    viewfinder.
    Sunchai.
    Can it be used in RZ67 ..??
  47. #447
    Senior Member Antonio Chagin's Avatar
    Jul 2008
    Miami-Fort Lauderdale
    476
    is this tech Cam?
    Hello Sunchai.
    Can you tell us how you got this together? Looks interesting but unknown.
    ACH
  48. #448
    Apr 2013
    83
    Quote Originally Posted by ckhfrankie View Post
    The construction of RZ camera is difference from the RB. And the most importance thing is RZ body is deeper so then the infinity focus is impossible.
    Sunchai.
  49. #449
    Apr 2013
    83
    Quote Originally Posted by Antonio Chagin View Post
    Hello Sunchai.
    ACH
    this may help some.
    Sunchai.
  50. #450
    Feb 2012
    10
    All my old Mamiya collections are come back to live again with FPS.
    I mean ALL! Plus tilt, swing, rise, fall and shift.
    Cheers
    Michael
