Results 1 to 7 of 7
Thread: how to use a ColorChecker Digital SG with C1 ?
    May 2009
    Marseille, FRANCE
    972
    is there a way to use it in order to profile the camera ?
    or can i use an other software (lightroom ?) to make the profile and importing it to C1 ?
    dwhistance
    Re: how to use a ColorChecker Digital SG with C1 ?
    I am not aware of a way of using it directly in C1 (but would be interested to find out if there is one!). You need a product such as Xrite's i1Match or similar with the camera profiling switched on. You may be able to find an operational trial that will allow you to produce a working profile but many of the software providers specifically prevent this. I have continued to use i1 Match for producing camera profiles for years, despite supposedly superior products being made available, as I refuse to buy software I have been unable to trial first.
    David Whistance
    Jan 2009
    Jeddah / Saudi Arabia
    126
    Besides Xrite's i1match there is a plug-in for Photoshop called "inCamera plug-in" from Pictoclor to generate an ICC profile and another plug-in "iCorrect EditLab Pro plug-in" to edit or modify it. This ICC profile can then be used in C1 as well.
    Regards,
    Udo
    Oct 2009
    Copenhagen, Denmark
    42
    Quote Originally Posted by archivue View Post
    You will either need to do it by hand (using the color editor) or build the profile using an external tool.
    To use an external tool, process the image in Capture One by embedding the color profile. Which profile you use is not important, since it is embedded and the profiler should ignore it. I would strongly recommend testing that with whatever software you use by using a completely weird profile as well as a reasonable one.
    The profile will depend on the film curve, so do select it appropriately. If you want a profile that measures well, use a linear film curve.
    Word of warning: while you should be able to get the Lab coordinates to match the theoretic values extremely well, an overemphasis on theoretical accuracy is almost guaranteed to result in ugly photos. Some people simply trust colorimeters more than eyeballs.
    May 2009
    Marseille, FRANCE
    972
    Quote Originally Posted by EsbenHR View Post
    yes i know, this is just for a special purpose...
    Los Altos, CA
    10,486
    1031
    Just to clarify, in C1 if you use the color editor tool you CAN save the resultant adjusted color settings as an independent icc profile, and C1 will allow you to apply it as your camera profile.
    home: www.getdpi.com
    May 2011
    Hong Kong
    691
    Jack, that is a very useful snippet of knowledge!
