iPad 2 CF reader with Phase files?
faneuil
just got iPadded before week long trip. Plan to use my phase back exclusively.
Does the CF card adapter from apple work with phase files?
that is, anyone have advice so I can avoid buying useless gear :)
goal: review the day's phase shoot on iPad
any app that is a must have to help the process?
thanks!
Eric
dougpeterson
http://www.captureintegration.com/2010/12/09/capture-one-pilot-for-ipadiphone/
You can use this to review the shoot on an iPad during or after the shoot. You'll be able to zoom to 100%, color tag the images, rate the images, view a histogram, view the image WITH any base-style (e.g. +10 contrast, +20 highlight recovery, +15 clarity) applied, and it's very fast (provided you set it up as we describe).
If desired you can do this without a router by using the "Create Network" (aka Ad Hoc Wifi) of any mac laptop.
Doug Peterson (e-mail Me)
__________________
Phase One Partner of the Year
Newsletter | RSS Feed
Buy Capture One 6 at 10% off
Craig Stocks
Are you taking a laptop with you, or wanting to use just the iPad? There are very few solutions for reading a CF card for an iPad. The Apple offering has an SD card reader and a USB adapter. Unfortunately, IOS 4.2 and later greatly reduced the power available for the USB adapter, which rendered nearly all USB card readers useless.
I've only seen two CF card readers for the iPad. You can read about them on Rob Galbraith's blog
http://www.robgalbraith.com/bins/content_page.asp?cid=7-11412-11522
http://photojojo.com/store/awesomeness/ipad-cf-sd-reader/
The way I read it though, you may have still have trouble reading CF cards larger than 4GB.
If you know of a better solution, I'd be happy to hear about it.
The other question is how to view the raw files on an iPad. I'm not sure if there are any photo viewers for the iPad that can read an IIQ file.
faneuil
thanks - saved me some $ there.
ideally ipad would travel with me only. I am using 32gb CFs!
sounds like a great opportunity for Phase.
and Doug thanks for the tip. I do plan to use Capture Pilot in studio situation when shooting tethered. Would be great to have phase proprietary app and hardware solution to review and quick flag images on iPad in the field.
quick surf shows that photosmith app doesn't seem to handle Phase IIQ files.
Eric
macoberly
I bought the original ipad for the express purpose of downloading my cf cards to it. When ios 4.xx came out they changed the amount of power draw allowed throught the power slot. This killed virtually all cf card readers. My solution was to buy a powered usb hub and connect it throught apples usb adapter. This works fine with two musts: Have the usb hub plugged in, and shoot with a .tif extention on the DB. Files will then transfert to the ipad. You cannot do anything with the files once they are on the ipad though. They look like crappy thumbnails. I do this with ios 4.xx and sandisk extreme 16gb cards. I havent updated the os though, things may have changed again.
Good Luck
Mason.
sflxn
Sad to say, but the iPad is not a good device for downloading your images. It neither have enough storage nor makes it easy for anyone using CF cards. Plus, downloading files takes too long (I tested with SD cards). If you can, I'd pick up a Macbook Air 11 with a big hard drive. I picked up the iPad 2 when it came out with the same expectation but have been very disappointed.
Loc
