Results 1 to 16 of 16
Thread: FRUSTATED
    Nov 2010
    622
    5
    FRUSTATED
    I have tried just about everything to download the Raw images from My Mamiya 645 AFD11 and Leaf Aptus 22 Back. I was able to get Leaf Capture 11.2.4. I can copy my images from my CF card to a New folder on my desktop. The problem is I am trying to get the Raw images to LR ver 2.7 It will not accept these images that I am trying to Import. If I convert the Raw to Jpg in LC it will go into LR. But I want Raw to go in so I can make my adjustments from Raw file and Not jpg. I just purchased this MFD system That I waited a LOOOONG time to get. Now I cant do anything. At this point I am willing to buy another Computer( newer one) and with software that I can upload with No problems. I now have a Power Mac G5 ver. 10.4.11 Is there a REASONABLE one I can buy for my purpose? I only shoot some portraits and some group shots and HOBBY. I do have an Ext HD 1 Tera. I dont need a lot of HD memory for my purpose. I want to be able to use C1 pro 6.0 to PP my images.
    Please advise as to my Best and Most economical way to do it. Thanks, rollsman
    Aug 2008
    California
    57
    Re: FRUSTATED
    rollsman,
    Typically the best workflow is to go from RAW in the vendors software (Hasselblad = Phocus, Phase/Mamiya = C1 and Leaf = Leaf Capture or C1). This is to get the best possible file to start work on, you basically take you .mos file convert it to a 16-bit tiff for output which can then be imported into you DAM (digital asset management) software (LR, Aperture, etc.). You can then edit in LR or go from LR -> CS4/5.
    Of course if you work directly in like C1 you can do lots of the editing and send it out directly to CS4/5 or even use Phase's MediaPro software as your DAM solution. But, if you like LR then this is they way I do it. I do it this way as I found that LR tended to massacre my .IIQ files if I imported them directly.
    Hope that helps!
    -Marq
    Nov 2010
    622
    5
    Re: FRUSTATED
    Thank you. I will give it a try. I was also told to try DNG converter and then to LR. Take care. rollsman
    Workshop Member glenerrolrd's Avatar
    Jupiter FL/Atlanta GA
    2,279
    Re: FRUSTATED
    [QUOTE=rollsman44;370767]I have tried just about everything to download the Raw images from My Mamiya 645 AFD11 and Leaf Aptus 22 Back. I was able to get Leaf Capture 11.2.4. I can copy my images from my CF card to a New folder on my desktop. The problem is I am trying to get the Raw images to LR ver 2.7 It will not accept these images that I am trying to Import.
    My guess is that LR 2.7 does not support the raw file produced by your Leaf back. I would look at the Adobe site to see if a upgrade to LR 3 would include the support for your file type. The upgrade is i believe $100 .
    The other alternative is to use Leaf Capture to do the raw conversion but output a TIFF format . Then input the TIFF for further editing and output options.
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,929
    Re: FRUSTATED
    Quote Originally Posted by rollsman44 View Post
    .. I now have a Power Mac G5 ver. 10.4.11 Is there a REASONABLE one I can buy for my purpose? ...
    Can't help you on appropriate software and workflow for that camera, but ...
    A current Mac Mini outfitted with 8G RAM and a fast hard drive will make your Power Mac G5 seem like a boat anchor, performance wise. A current iMac 27" will do the same, moreso ...
    You need a modern, Intel-based Apple system to run Lightroom 3, and Mac OS X v10.6. It's time to get into the modern era if you actually want to get the most out of your medium format digital camera setup.
    Having a modern computer and correct software is at least as important as having a high end camera and lenses if you want to do great work with your photography. It's probably more important.
    23,623
    2555
    Re: FRUSTATED
    I have to agree here updating your computer to at least intel based will be far better.
    www.guymancusophotography.com
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    Re: FRUSTATED
    Some 0 investment suggestions
    A slight mor expensive option (at the cost of a phone call) would be to call you dealer and ask them to guide you through it
    Enjoy your new kit
    London, UK
    1,168
    38
    Re: FRUSTATED
    A slight more expensive option (at the cost of a phone call) would be to call your dealer and ask them to guide you through it
    Enjoy your new kit
    May 2010
    36
    Re: FRUSTATED
    Hi Rollsman. Anything intel will do. I am glad you want to use C1 for your images, and I am sure you know that if you own an Aptus then C1 is free. If I hear one more person whine about wanting to use Lightroom with their Aptus I think I will scream.
    There have been several threads recently both here and on Lula about this. It is just so wrong. ( Just my opinion mind you ). But I loath Lightroom. If you are going to spend the coin an a back, use the right software for Pete's sake, it is free and will give you a much better result than one size fits all Lightroom. I know this will ruffle feathers, but it is true.
    Jason.
    Nov 2010
    622
    5
    Re: FRUSTATED
    You are correct about me updating my system to a NEWER one. My issue is transferring ALL my data files, programs etc in my current computer to a new one without losing some or having a proble after that. I will look into a Mini or Imac. Thank you, rollsman
    I did not think it would make a big difference in PP my images. Is it possible to explain how or why I would get better image quality? Thanks
    Godfrey's Avatar
    Jan 2009
    7,929
    Re: FRUSTATED
    Upgrading to a newer system will mean
    a) you can run the latest versions of all the image processing software you use, taking advantage of whatever improvements have been made.
    b) image processing will work much more speedily and responsively, making it easier to do what you want to do in rendering your image files. The faster and more responsive the tools become, the more time you can spend trying things and improving your photographs.
    Transferring your data and applications to a newer Apple system is easy, Mac OS X provides the tools required to do it automatically (on Mac OS X Lion, for instance, see the "Migration Assistant" application in the Utilities folder). Just follow the instructions. Some older software will no longer work ... you replace those apps with the latest versions or with new software that replaces the functionality. The replacements are generally more capable and work better.
    You can make an appointment at an Apple Retail Store with one of the Genius Bar or 1 To 1 customer training/service folks to guide you through the process if you feel you'd like some assistance.
    NYC
    3,275
    7
    Re: FRUSTATED
    +1
    The free weeky software trainings and by appointment setup / 1-on-1 training are some of the most underutilized services in the world of computer retail.
    Santa Monica, CA
    2,274
    2
    Re: FRUSTATED
    No one's mentioned this, but if you're concerned about data files, you'd be well advised to have them backed up on a drive or other media outside your computer. Moving data to a new Mac is easy, as has been said, but I think it would be wise to have your data backed up.
    Nov 2010
    622
    5
    Re: FRUSTATED
    Thanks again for your suggestions and I will look into them, Greatly appreciated. rollsman
    Member Analog6's Avatar
    Jun 2008
    Terranora Northern NSW Australia
    151
    Re: FRUSTATED
    Does your version of Lightroom have the latest file recognition updates (not sure what they are called) from Adobe. I think you go to something like RAW files support and you can download 'interpretation' files for the various Adobe products. I had to do this when I purchased my Lumix FZ35 as my version of Photoshop did not have the right downloader recognition files.
    Try this page - there are some camera RAW updates there
    Odille
    H2 | P20 | HC 50-110 | HC 150 f3.2 | HC 210 f4 ~ My Website
    Nov 2010
    622
    5
    Re: FRUSTATED
    I dont know but thank you for the suggestion. I will check it out, rollsman
