Results 1 to 8 of 8
Thread: Using LCC with MFB and tech cameras
    Feb 2009
    793
    when using a medium format digital back(IQ160) on a technical camera(cambo)
    at what focal length is LCC required/beneficial? would you use LCC for all lenses?
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    Re: Using LCC with MFB and tech cameras
    I have used LCCs with focal lengths up to 90mm--don't have anything longer.
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    use them when you need them.
    Actually there is no real hard and fast answer.
    For those shooting an SK lens, they will find it necessary at longer focal lengths maybe up to 90mm or so, for those shooting a retrofocal design such as a rodie HR you might find that you might be ok up to about 70 mm or even less.
    That is assuming that the back is centered. Once one shifts you will find it necessary more often.
    I make it a habit of ALWAYS shooting an lcc image mainly because you don't know that you really need it until later in post processing.
    Now besides necessary due to color cast, it is also useful for reducing fall-off and even dust depending on the settings used when processing the lcc.
    Bottom line, go ahead and shoot one. Bits are cheap and a missed shot due to the lack of a proper lcc is expensive.
    -bob
    Brooklyn
    4,043
    1253
    as last defense, you can always shoot one later if you re-create the shift, tilt and aperture, maybe focus setting
    Vancouver, WA
    5,802
    564
    The real secret is to have a repeatable workflow so that you don't forget to shoot LCCs. Once you have that and you've acquired the requisite muscle memory it all becomes very simple, quick and easy.
    Brooklyn
    4,043
    1253
    now Graham, don't forget the messy part of cataloging and labeling all those LCC shots one accumulates over the years, especially not even knowing how/where Phase places them
    Vancouver, WA
    5,802
    564
    You have a good point there although I've given up on labeling them actually.
    In each session I'll shoot the LCC in order with the main images and then use the image number to find the right one - the LCC will be obvious from how close it is in sequence # to the image shots and also I always shoot them in order from left -> right or rise -> fall plus the obligatory blank frames with my hand between set ups. I typically shoot the scene with the set up and then the LCC set at the end before I make a movement change. The LCC drop down does get longer & longer & longer though over time, at least until Phase One fix this aspect of the workflow.
    Right now I don't have tilts to contend with as well though. Instead I have to remember to label focus stack sequences which I also try to always shoot in the same order.
    KISS works for me. Mostly. :-)
    For the OP: I shoot LCCs for all lenses up to my Rodenstock 90 HR-W. I don't normally bother with the 90 unless I use movements in which case I will although it's seldom necessary although as Bob mentioned you do get the benefit of dust removal if you shoot an LCC.
    Feb 2009
    793
    Thank you for the advice.
