Results 1 to 8 of 8
Thread: need help with a calculation
    Senior Member danlindberg's Avatar
    Aug 2010
    Spain & Sweden
    1,196
    I do not know how to calculate the following.
    A two image stitch with 10mm shift left and 10mm shift right.
    Vertical position and then crop to exact same aspect ratio as a (one) normal landscape image.
    Using a Schneider 35 XL.
    How wide a lens would that correspond to a (1) 36x48 sensor and (2) 33x44 sensor?
    Alpa FPS MAX TC | Alpagon 32Hr | Helvetar 75 | Schneider 120N | Leaf Aptus II 5 Leaf Credo 60 | www.danlindberg.com
    Mar 2010
    Germany
    253
    Re: need help with a calculation
    You can use the Alpa lens calculator for these calculations:
    http://www.alpa.ch/en/products/tools...alculator.html
    In the xls file, it's the "Free calculation" sheet which allows for the calculation you want to do.
    CI has provided something similar but I don't have a link at hand.
    Chris
    Dec 2010
    Warks, UK
    550
    Alfa calc looks good, and calculates results for shift and stitch, but Barnak has a focal length slider which you could use to find the focal length.
    ...or you can look up the formulae and do some trigonometry. (I presume that these on-line and down-loadable calculators are more accurate than the simple "thin lens" formula.)
    Quote Originally Posted by danlindberg View Post
    Shashin's Avatar
    May 2011
    Florida, USA
    4,501
    141
    Actually, it is easy. Calculate the diagonal of the image area of both formats/image areas. Take the focal length used on one format and divide it by the diagonal of that format. Take the diagonal of the second format and multiply it by the product of the first calculation; that will be the focal length you need.
    This does assume infinity focus, for closeups it is trickier, but this will be a good ballpark.
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    971
    Dan,
    Here's what I get
    36x48
    To keep the same ratio, stitched image would be 56x42
    70mm diagonal, so focal length is 30mm
    33x44
    Stitched image would be 53x39.75 (again, keeping the 1.33 ratio...)
    66.25mm diagonal, so focal length is 29mm
    Dave
    Dec 2010
    Warks, UK
    550
    Assuming that a lens acts like a glorified pin hole at the focal length (plus extension if the subject is not at infinity) from the sensor, the focal length is half sensor dimension divided by the tangent of half the angle of view?
    The sensor dimension can be the width, height or diagonal, depending which angle of view you want.
    Feb 2011
    Northeast Ohio
    971
    A bit more info...
    To get the 56x42: a vertically shifted 36x48 would be 36+10+10 = 56x48, but that's the wrong ratio, so you would crop off 6mm to get to 56x42 (1.33:1).
    The base sensor diagonal is 60mm, and the shifted / cropped diagonal is 70mm. 35mm*60/70 = 30mm
    Dave
    Aug 2010
    Spain & Sweden
    1,196
    Thank you all, so much! What a great forum this is
