Results 1 to 8 of 8
Thread: Hasselblad 110mm F2 manual stop down
    Not Available
    Oct 2011
    471
    I just received a used Hasselblad 110mm f2.
    Nice and clean....
    But the iris does not stop down.
    Stopping it down the iris does not close and the depth of field preview button does not make it stop down either.
    I have checked that the little rotating linckage to the camera is cocked (wound up)
    Has anyone had this repaired?
    Feb 2010
    53
    Re: Hasselblad 110mm F2 manual stop down
    not shure if I understand what procedure you did. the aperture ring is kind of a "preset" ring. set up the aperture you want and then push down the "little lever" on the left side to stop down to the presetted aperture. if you leave the lever clicked in you also can turn the aperture ring and have the blades moving.
    Subscriber Member KurtKamka's Avatar
    1,232
    26
    I had that happen on a used 110/2 that I purchased. I ended up sending to Hasselblad USA for repairs.
    Kurt
    Member Seascape's Avatar
    Toronto
    239
    Apparently there were some aperture blade problems with the "F" series lenses (the first series 110's that don't have electrical contacts).
    The later "FE" 110's apparently have modified aperture blades that corrected this problem.
    Not Available
    Oct 2011
    471
    Quote Originally Posted by KurtKamka View Post
    Kurt
    Hi Kurt
    Was it expensive to fix?
    polarcircle
    This problem occurs with some of the F-series lenses. The heavy 50 f2.8 suffers from it. Here the aperture can break down wherefore one should make visual inspection of the lens that there are no internal scratches.
    I fixed my F 50 for 150 Euro.
    R
    1,232
    26
    If I remember correctly, the cost to have it repaired, cleaned and brought up to specification was somewhere between $150-$200.
    polarcircle
    Actually one should expect to have regular service on Hasselblad lenses. They function very well but need regular service. SOme type a little bit mre regular than others. So iif you bought a second hand lens you should actually service it unless you have papers from the seller of when the last service was done.
