Results 1 to 8 of 8
Thread: Which lens HCD 28 or HC 35
    Aug 2008
    Jonesboro, Arkansas
    27
    I am wanting to purchase one of these two. The primary purpose is architectural work, the closest lens I have to these currently is the HC 50-110.
    Thanks in advance,
    Greg
    Senior Member Swissblad's Avatar
    Oct 2011
    1,204
    Re: Which lens HCD 28 or HC 35
    I'm sure others will jump in with more conclusive advice.
    The HC 28 is unique in MF - if you have a large chip (H4d-50 or H4d-60), the results are spectacular - check out:
    http://www.hasselbladdigitalforum.co...ic,1442.0.html
    What what I've heard, the HC35 is not as sharp as it could be with modern high res backs, and is due for a replacement ala HC50 or HC 120.
    Jul 2010
    Kentucky
    362
    5
    Quote Originally Posted by Swissblad View Post
    That may be true, but I have been very satisfied and pleased with my HC35. Maybe I am not as discerning as I should be, but I print large and have never had a problem with resolution or for that matter any other technical issue. However, I would love to have the HCD28 even though I would lose some crop since I am using the H4D60.
    If you look at my images on this site, you will see the image of the house that was taken with the HC35.
    Greg
    Aug 2008
    Jonesboro, Arkansas
    27
    I have the H4d-50, how do you think it would work with that back?
    Thanks,
    Greg
    Sep 2008
    Lyon, France
    225
    49
    Quote Originally Posted by Greg Haag View Post
    Thanks,
    Greg
    The HC28 works very well with the H4D50 (I have this camera)
    The 28 is my favorite lens. The 35 is supposed to be lens sharp, and I use the 50 mm2 which is very sharp.
    Aug 2008
    Jonesboro, Arkansas
    27
    Jerome,
    Sorry it must have been a wishful thinking typo, I meant to say I have the H4D-40.
    Thanks,
    Greg
    Oct 2008
    Saffron Walden, UK
    1,983
    58
    Thanks,
    Greg
    Hello Greg
    The 28mm is very sharp. I use it on H4D -50.
    I dont own and have never used HC-35. However I did own a HC-50 which I replaced with the HC-50 II and appreciated the better resolution from the newer lens particulary at the edges of the frame. The original HC-50 looked ok until I saw how much better the MkII version was. If the same is true for the 35 then I suspect you will be happier with the 28.
    Quentin
    Quentin Bargate
    Aug 2008
    Jonesboro, Arkansas
    27
    Quote Originally Posted by Quentin_Bargate View Post
    Hello Greg
    Quentin
    Quentin,
    Thanks for your insight. The 28 is the lens that I think would be the most useful for me.
    Thanks again,
    Greg
