Results 1 to 7 of 7
Thread: Mirror Lock Up on Hasselblad 503CW w/ Aptus
    Mar 2011
    61
    This may be a dumb questions but...
    I just received my Leaf Aptus II 5 for my Hasselblad 503CW. If I use mirror lock up/pre-release the back says "an image was not recorded" (or similar)
    Is it not possible to use the pre release with a digital back ?
    Any help is greatly appreciated.
    Jan 2009
    Jeddah / Saudi Arabia
    126
    Re: Mirror Lock Up on Hasselblad 503CW w/ Aptus
    Hi there,
    are you using the 503 with the winder CW? And if so is the back connected to the winder or lens via trigger cable?
    Best regards,
    Udo
    Mar 2011
    61
    No winder. Thanks.
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    If you're not using a winder then the back/ software should be set to 500 series then it should work fine
    Yair
    Mar 2011
    61
    It is set to the 500 series body. The problem seems to be intermittent, it works fine about half the time.
    London, UK
    1,168
    38
    I suggest that you contact your dealer and have them look into it for you, it could be the sync cable or your lens that are playing up
    BR
    Yair
    Jul 2009
    455
    I used a P30 back with a 503CW and this can happen if:
    - your sync cable isn't sitting fully, especially on the lens body
    - you let go of your shutter release too fast. Wait until you hear the shutter closes down fully before releasing the button
    - you "half-press" the shutter button for too long. The best is only "half-press" the shutter button for about a second (to wake up the back if needed) and then press it fully.
    Beware that for long exposure (e.g. 1 second or longer), some of the new but not newest lens will shut off the sync signal in the middle. Hasselblad can fix them for you in that case. Some older C lens may also not send the sync signals reliable, especially for longer exposure (e.g. less than 1/15).
