Results 1 to 4 of 4
Thread: Hasselblad Film Back Problem / Glitch?
    Senior Member Chris Giles's Avatar
    Jan 2012
    Brighton
    342
    Over the weekend I've had some issues with film in my H1.
    The film will be loaded, will wind on fine but sometimes when I go to take the shot the film won't wind on. The low battery light was showing in the back's window and I changed it, put the film in and took a couple of shots. All seemed fine.
    Now, before I go on the film would unwind fine. Suggesting there was enough power there before changing the battery but anyway....
    Fast forward to today and again the film was not advancing. The only way to make this happen was to remove the battery and reinsert it. All then was well again. It seems as if when the camera is left for a while it 'forgets' the back is there.
    Has anyone had this happen to them?
    Member carl-b's Avatar
    Feb 2011
    Birmingham, uk
    93
    Re: Hasselblad Film Back Problem / Glitch?
    Hi Chris
    Not sure if this will help, but have you tried the battery reset option? If it's the 7.2 v battery?
    Jan 2012
    Brighton
    342
    I'm using standard disposable batteries and the 7.2v is rechargable I think?
    Feb 2011
    Birmingham, uk
    93
    Quote Originally Posted by Chris Giles View Post
    It is yes, so i guess the reset won't help. Doesn't seem to be much info out there in google.
