Results 1 to 5 of 5
Thread: Cambo X-2 Pro
    photographist
    Cambo X-2 Pro
    Good day all!
    Has anyone used the Cambo X2 Pro in the field at all? I'm focusing (pun intended) in using the Mamiya AFD body, Phase One Back and SK/Rodie lenses.
    Thanks!
    jvdk
    Oct 2008
    Munich
    876
    Re: Cambo X-2 Pro
    That was a good one. Sorry, but I have now idea how to focus without live view or a ground glass.
    420
    4
    Re: Cambo X-2 Pro
    Quote Originally Posted by photographist View Post
    Good day all!
    Thanks!
    jvdk
    JV -
    You can mount the AFD on the X2 and you can then see through the ground glass. Your caveats include some limitations on lenses wider than 80mm. Also, the DF body might not be ideal for this in a field situation, as it would need a power source to keep the body from going to sleep with non-electronic contact lenses. The AFD body should be ok, as long as it is set to not go to sleep.
    Cambo X2 :: Capture Integration Medium Format Digital Back Sales & Rental and Other Professional Photographic Equipment
    Steve Hendrix
    Digital Cam: Phase One | Leaf | Leica | Sinar Authorized Reseller
    TechCam: Alpa | Cambo | Arca Swiss | Sinar Authorized Reseller
    photographist
    Re: Cambo X-2 Pro
    Hi Steve ...
    What are those limitations? Using the recessed board, how wide can I go? The body is an AFDii, btw.
    Thanks!
    jvdk
    420
    4
    Re: Cambo X-2 Pro
    Hi Steve ...
    Thanks!
    jvdk
    Infinity focus limitations, depending on the lens. So, Schneider/Rodenstock lenses need to be about 80mm and longer. The older Schneider 28mm/2.8 - not the newer one - will focus, but it has other limits as well (restrictive image circle, for one). The Hasselblad 40mm/50mm won't go to infinity. RZ lenses will (different design).
    Steve Hendrix
