Results 1 to 4 of 4
Thread: Tech camera caught in a downpour
    Member schuster's Avatar
    Mar 2011
    New Hampshire, US
    129
    11
    You tromp with tripod, Cube or other pricey head, Alpa/Arca/Cambo/Linhof/Plaubel/ArcBody/etc tech cam and attached Rodenstock/Schneider/Fuji/etc lens and PhaseOne/Leaf back, to a vantage point 1000ft/305m from your car. You make some excellent captures and completely unexpectedly, you and your gear gets drenched in a downpour.
    You run back to the car with your gear... then what? Probably the Phase/Leaf back is just fine, but do you let everything air dry without touching any controls... or towel dry with or without removing lens and back... or hit everything with a hair dryer as soon as you get home... or ????
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    Re: Tech camera caught in a downpour
    I would dry it with a cloth and then put it in an air-tight container/bag with some desiccant overnight to suck up the moisture. I would not heat it with a hair drier.
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    I know this is a little late, but when I carry my camera around my neck, I slide a waterproof stuff sack over it to act as lens/camera protection from dust and stuff--I just cinch the string to hold it there. The sack goes in my pocket while shooting, but in a spot of bad weather, I can put it over the camera, even if mounted on a tripod.
    Don't worry too much. A member has already dropped their Leaf back into water and it seems to have survived.
    Shashin's Avatar
    May 2011
    Florida, USA
    4,499
    141
    One more thought. Call your dealer and ask what they recommend--it seems to be a common problem with Leaf/Phase owners.
