'Hot pixels!'
D
drmytan
Recently l tried long exposure shots with my H4D31 and just realised this camera only gave the bulb maximum time of 64sec ... how to use my newly purchased Lee's big stopper 10x filter?
Now my real question is l noticed especially when using the wide-angle lens of 28mm together with filter (CPL or ND) and with longer exposure l noticed red and blue pixel type patches/spots on the shadow areas. Are they called 'hot pixels' due to the long exposure generating the heat on or from the sensor as explained by my dealer here? Sorry l am not the technical genius but love to shoot photos only.
How on earth can l reduce this? By not doing the long exposure shot, so what is the ideal exposure time to avoid this sort of artifacts? Any software to overcome it? Anything in the camera setting to use to stop it? Editing by photoshop doesn't help much.
Is it possible to increase Bulb time beyond 64sec (after l have solved my problem of 'hot pixels')? Otherwise no point of doing more than 64sec if one still gets the hot pixels.
Thanks for any comment and suggestions
Jeffg53
Did you process the image with Phocus? I have never seen a hot pixel shooting up to 4 minutes on my 40, and 64 seconds on the H3D 39.
D
drmytan
Yes all the images are open and processed with Phocus then edited in Photoshop CS5. Which function in Phocus can l use to reduce these artifacts?
Regards
Jeffg53
There is no function that I know of. I have seen hot pixels appear while Phocus is processing a file but they disappear as soon as it is processed. Can you post an example? Also are you using the standard settings when importing?
D
drmytan
After the minimal process done in Phocus, l export it out as Tiff 16 (chose 16bit) with resolution 360 ppi file. Then open it in PS to continue more pp work.
Cheersv:)
Wayne Fox
Did you have the dark frame subtraction option enabled on the camera when you took the picture? Normally the camera masks out these pixels with this process.
cunim
I notice you are in Malaysia. Do you shoot in warm temperatures and high humidity? As you know, integration noise (thermal or dark current noise) is temperature dependent (doubles with about a 6'C increase) and the CCD can really heat up if ambient cooling is not working well. Long exposures work better in the winter - where there is a winter. Stick the camera in a fridge and then qiuckly take the same image. That will tell you if you are seeing an integration noise issue.
D
drmytan
Well! l live in Malaysia but l travel often and only use it when l go oversea. I usually travel to the temperate countries. Thanks
D
drmytan
Hi guys .. first of all as referred to my questions, l am still not clear how the hot pixels look like. What l mentioned at the top is the information l had from the retailer. Looking at the picture taken in Prague recently, l noticed some pixel artifacts on the shadow areas around the dark water when zoomed in. Are they the hot pixels?
Maybe can someone show me how the hot pixels look like.
THANKS
D
drmytan
For my P65+ I just apply a 1 pixel dust and scratch filter in Photoshop. That clears up nearly all of the hot pixels,
Hi! Thanks for the info on this. Sorry whereabout exactly these functions can be found in CS5?
Cheers
