Results 1 to 20 of 20
Thread: Pano stitch test Single row
    23,623
    2555
    Well I thought I would share this. I shot a 8 shot vertical stitch with my Pano Elements package and the 28mm mamiya. Got everything lined up and just shot 8 frames by panning across than in Photo merge let it go on auto. Worked very nice but I still have the bowing with ceiling and wall . Not a straight across line. Now this has to be becuase of the 28mm super wide and a longer lens would be better at this which is fine so here is the result of that at F16 2 seconds each exposure. This is a test and did not light anything
    www.guymancusophotography.com
    23,623
    2555
    Re: Pano stitch test Single row
    Now I got the bright idea of doing a select all than go into edit to transform as see if I can work this a little. So I went to the warp tool and you will get 4 points across the top of the frame one on each end than 2 in the middle . So what i did was bring the 2 in the middle down under the lines straightened out as much as possible . Than hit okay , than what i ddid again was select all , transform and hit distort this time and pulled the whole top up to stretch it back up. And it actually worked pretty good. I could play more but this looks pretty good and i know this all has to be because the use of the wide angle and a longer lens probably would not do this to the ceiling wall but not always a choice to go longer so need to figure a way to make it better and this may not be a bad way to go
    23,623
    2555
    There maybe some other tricks on doing this also and need to play more but a interesting CS3 tool. Now CS4 is supposed to be better at Photomerge, we will have to see
    Manchester/Jerusalem
    2,652
    290
    I don't know what tools you have with your pano elements package but I use Autopano Pro and I know PTGUI has the same feature of making a rectilinear pano where you can specify which lines you need to be straight in both horizontal and vertical. That and a very powerful vanishing point tool means that you have a huge amount of control over your pano to make it look as natural as possible.
    23,623
    2555
    Ben the Pano elements package is here http://reallyrightstuff.com/rrs/item...atus=0&Tp=&Bc=
    yes another software package maybe the real answer. have to check out autopan pro
    Workshop Member MikeScecina's Avatar
    Albuquerque, NM
    103
    21
    Note to self: When shooting for the money turn off ceiling fan.
    Subscriber Member TRSmith's Avatar
    Central Maine, U.S.A.
    2,406
    9
    Did you try the lens correction filter in PS3?
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Hi Guy
    I reckon you need other software.
    Incidentally, how big are you going to print this! Presumably it'll be larger than the room!
    Just this guy you know
    23,623
    2555
    Quote Originally Posted by TRSmith View Post
    Yes Tim I did , did not do much at all.
    Yes Mike turn fan off , LOL
    I would have if I was shooting for real
    23,623
    2555
    Hi Guy
    Well this I won't print it's my family room , my hangout when i don't have kids in my ear. LOL But it looks like it would print very well in a big size
    23,623
    2555
    Sounds like Autopano might be the better software when you get into this kind of straight line stuff. For landscape work i would think Photomerge will be just fine
    4,333
    Guy – I’m a little surprised that you couldn’t have gotten the same image in either one shot or two on top of one another on a horizontal plane, or did I miss something……
    don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    23,623
    2555
    I probably could Don , I know i need to shoot something pretty specific in a couple weeks and it will HAVE to be vertical stitched, bathroom actually and just seeing what I need to do to get that done because i know I will run into the ceiling wall issue there . But nice thought about horizontal up and one down , that maybe useful also. Hmmm maybe add one more part to my Pano tools to do that easier
    4,333
    Guy – You can borrow my RRS pano kit if you want/need it.
    don
    Don Libby
    Blog
    Tucson AZ
    23,623
    2555
    heck you may not need it anymore. ROTFLMAO
    Okay just for shits i did the same thing as a horizontal pano
    2,652
    290
    Autopano pro have a good trial software, does absolutely everything including full sized output but puts a watermark so you can really see how well it's working. There are a few bits and peices that can be confusing, I know the program pretty well, please PM me if you have any problems.
    Tip 1: When you import the images click here for the Edit window,
    Select 'Planar' projection (what they call rectilinear),
    Then draw in your horizontal and vertical lines:
    2,652
    290
    History tool which works like in PS:
    Vanishing/Center Point tool, far easier than using perspective adjusments or the Yaw/Pitch/Roll tool. Note the cropping tool on the left hand side to get rid of the black areas post adjustments.
    It is very important for trouble free stitches to set up the focal lengths used do the program knows what distortion correction to apply otherwise it can get very confused. This is done via the original import images window.
    2,652
    290
    Hope this helps, their documentation is rather basic if you just want to get on with making rectilinear/architectural style stitches.
  19. #19
    23,623
    2555
    Thanks Ben I did go and look at it , seems to be the one I will need. Some tools there that really will straighten things out.
  20. #20
    Subscriber robsteve's Avatar
    1,202
    496
    Ben:
    How do you set the color space of the exported file in AutoPano Pro?
    Robert
