Results 1 to 12 of 12
Thread: Architectural stitching with MFDB
    buzzski
    Hello, I'm curious to see if any of you are shooting architectural with MFDB and stitching afterwards. I'm shooting Blad V/Aptus 17 combo and my widest lens is 40mm. I've tried some tests shooting either 50mm and 80mm then stitching with PTGui trial version which have been OK but I'm wondering if any of you have experiences you could share that may prove more successful. I haven't been using a specific pano head but have been basically shooting say four shots over three rows on a normal B&S head allowing sufficient overlap. Any advice would be very much appreciated, thanks, Craig
    London/Kiev
    1,079
    Re: Architectural stitching with MFDB
    what problems are you having?
    Senior Member JimCollum's Avatar
    santa cruz, ca
    936
    155
    i shoot with a Horseman SWD-II Pro and the 35mm lens, and the Aptus 75. I've stitched images (giving the equivalent of 14mm on a full frame DSLR) with no problem (lens cast can be fixed with vendor supplied software)
    santa cruz, ca
    936
    155
    Quote Originally Posted by buzzski View Post
    you can achieve similar results with a pano head, but it's a little harder to be certain that you have the shot when you leave the customer site. I'd recommend being very liberal in your shots.. shooting a lot more at the perimeter of the shot to make sure that there will be enough room to transform the image to be rectilinear
    211
    Jim,
    I really like the composition of the first two shots. They work as wholes, but also as 4 or more rectangular shots. Keeps the eye exploring.
    Best,
    Mitchell
    Apr 2008
    Sydney
    251
    Jim,
    do you shift the back or the lens?
    The reason why I'm asking,that when you shift the lens you could have issues with parallax. Please correct me if I'm wrong.
    Also what about white shading of the files?
    Regards,
    Willem.
    santa cruz, ca
    936
    155
    Quote Originally Posted by Rethmeier View Post
    Jim,
    Regards,
    Willem.
    With the Horseman, you shift the back.. which eliminates parallax completely. The Leaf software has a 'gain' adjustment program.. you take a shot through a opaque white filter for each of the shifts.
    Apr 2008
    Sydney
    251
    Hi Jim,
    that's exactly what I thought and would do myself.
    Thanks,
    Willem.
    buzzski
    Thanks for that Jim, you have achieved exactly what I am trying to capture. I notice you are using a 35mm lens with a shifting back. I have the option to use 40, 50 or 80 lenses fixed on a Hasselblad. I was worried about using the 40, although I'd be capturing a wider area I was concerned about distortion which would be greater than the other two lenses... Having said that, shooting on an Aptus 17 I am using the sweeter spot of the lens. Do you think I am struggling without using a pano head and if so without breaking the bank can you recommend one that will support a MF camera? I also take your point that it's a bit disconcerting that once you've shot your images, your not really 100% sure that they will stitch together successfully. Thanks for all your help, I've just joined the forum here and am delighted at the response so far.
    buzzski
    Hi Graham, thanks for your reply. I'm just starting to play around with stitching as a viable way of shooting interiors (and to that exteriors which I've done reasonably well) and am looking for other peoples experiences regarding lens choice, software to stitch and whether a pano head is a necessary purchase. I loved your image on LL boards a week or so back of a three-stitch exterior building at twilight. Can you elabortae on how you achieved it? Thanks again, Craig
    Brooklyn
    4,043
    1253
    in case you didn't see it, I am offering a Horseman SWD 2 and Rodenstock 35mm setup for sale. Same rig as Jim's
    jm
    buzzski
    jm
    I would love to... and at such a reasonable price too, however I'm just not in a position to make such a big spend at the moment, I've upgraded digi back, blad body and two lenses this year already, I fear this would be a step too far! Thank you though, Craig
