Hi Paul and welcome to the forum.
Whilst your 200 series cameras and F/FE lenses are great as are the CFi and CFE lenses - if you wish to use these lenses on a 200 series body - you need to use a CFV/CFV11 back and lovely as they are - you are restricted to a 1.5X crop.
If one chooses to use a different back with a V mount one is restricted to a 1/90th shutter speed - is this correct?
A few people I know are actually using Contax or Mamiya bodies in order to be able to use the F/FE/CFE lenses they so admire - without crop and without the shutter speed limitation.
I suspect that that is why people are asking for a focal plane body from Hasselblad - which can use their faster F/FE series lenses - somethign we cant do with the H series body dediaetd to Leaf or C/CFi/CFE type lenses via adaptor. I guess teh F/FE lenses are so good that many of us wuld liek the ability to use them on a hassebald body with a large chip.
pete
Hi Pete,
Option 1
With a modified 200 series camera you can use the F/FE lenses without a synch cable with CFV/CFVII, communication is handled via the Databus (4 gold contacts) on the rear of the 200 camera and CFV/CFVII back. Flash synch will be 1/90 second.
Option 2
With a 200 series camera you can use the F/FE lenses a with CFxx and use a Kapture Group single shot cable. Flash synch will be 1/90 second.
Option 3
Dis-engage the focal plane shutter on the 200 camera by setting shutter speed ring to C position and attach a C, CF, CFi, CFE lens. Attach a flash synch cable from lens to CFV/CFVII. Menu on CFV/CFVII must be set for "Flash synch"
Flash synch is now available to 1/500 second.
You can use any of our products (CFVII, CFII39, CFII39MS) with this configuration.
The H system was 7 years of planning, designing, implementation before becoming a reality in September 2002. Hasselblad made many decisions over the course of those years regarding what would be the most important features to include in an entirely product. Fast flash synch to 1/800 second was deemed very important and also allowed Hasselblad the maintain the tradition of utilizing a Central shutter within their lenses.
Paul Claesson
Hasselblad USA
