Results 1 to 11 of 11
Thread: Pentax 67 lenses on MFD SLR system
    Senior Member Ed Hurst's Avatar
    Sep 2008
    Sydney
    1,161
    Hello all,
    Following my earlier (stupid) question, I have a different question! If I want to use my Pentax 67 lenses on a Medium Format digital SLR, what option do I have? The only one I can think of is the Phase system of backs with a Mamiya (or Phase or Leaf) body, and trying to find a mount adaptor to mount the lenses. Is this possible? Does anyone know of such a mount? Would the lenses work properly this way? Would the autofocus system provide focus confirmation if I were to use an adaptor?
    Thanks in advance for your advice!
    All the best,
    Ed
    Berlin, Germany
    143
    Re: Pentax 67 lenses on MFD SLR system
    i have a pentax 67 adapter for contax 645 bodies if that is what you're looking for. bought it from zoerk about two years ago and used some pentax glass on my contax. works well for some applications where speed isn't an issue.
    Sep 2008
    Sydney
    1,161
    Thanks for that - appreciate it. Does the AF system provide focus confirmation when you are using Pentax 67 lenses on this body?
    Berlin, Germany
    143
    yes, if i remember correctly the focus confermation works as well.
    NYC
    3,275
    7
    Yes, you can use it on the Mamiya 645 AFD, AFDII, or Phase One 645 via an adapter. In each case the AF Focus Confirmation would still work.
    Those bodies will accept Hassy 200, Hassy 500 (V), Pentax, and all sorts of other whacky glass while maintaining some degree of aperture-priority metering and AF confirmation.
    Doug Peterson, Head of Technical Services
    Capture Integration, Phase One Dealer
    Personal Portfolio
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    Quote Originally Posted by dougpetersonci View Post
    Personal Portfolio
    Doug, what is your experience - if any - of the older non-AF Mamiya lenses on the Phase One/AFDIII? Page 83 of the Instruction Manual says they will not work with stop down metering - which is true of my 80.f1.9 and 200.f2.8. Focus confirmation works but the metering gives nonsense readings.
    Yet Jack, elsewhere on this forum, has found that one of his old Mamiya lenses does work. What's your take?
    Bill
    Manchester/Jerusalem
    2,652
    290
    The MF mamiya lenses won't work properly with the AFD bodies? That's not good.
    Sep 2008
    Sydney
    1,161
    Thanks everyone for your help so far on this. It's exciting me, because it's making me think that jumping to medium format digital might be possible for me (it kinda depends on using the P67 lenses I already have, at least in the short-term).
    Just one follow-on question. Doug, you said "Those bodies will accept Hassy 200, Hassy 500 (V), Pentax, and all sorts of other whacky glass while maintaining some degree of aperture-priority metering and AF confirmation." The phrase "some degree" is concerning me a little! If I use P67 glass with an adaptor, can I expect to be able to meter with them, or might I have the same problem experienced by some of the manual focus Mamiya lenses?
    Many thanks.
    Aug 2008
    2,535
    184
    Ben, I think they may work with the original AFD and the AFD II - but not with the AFD III. But I'd love for some other AFD III users with manual lenses to confirm this.
    Bill
    NYC
    3,275
    7
    Don't know where that info came from...
    As I said, MF lenses work on the Phase One 645 (same as AFD III). You'll need to place them in M mode (manual stop down) and metering is locked to center point and is hit-or-miss. The Autofocus Confirmation system works perfectly, so as you focus and the AF-confirmation system will tell you when you are in perfect focus for that subject.
    These lenses are not a great replacement for a Sekor D as a main lens. They tend to be less sharp wide open and exhibit more chromatic aberration. But they are still pretty good lenses and are an amazingly inexpensive way to expand your available line of glass. For instance an 55-110mm f/4.5 lens in excellent condition can be had for $199. If you're photography calls for a zoom to be your main lens then this would be a terrible choice compared to one of the new Sekor D zooms, but if you're primarily a landscape shooter you could pick up this zoom lens for that rare occasion when you need something longer.
    Here is a sampling of the MF lenses which could ship today from KEH.com
    35mm f/3.5 - bargain condition - $159
    45mm f/2.8 - excellent condition - $215
    55mm f/4.5 - excellent condition - $199
    80mm f/4 Macro - excellent condition - $149
    110mm f/2.8 - poor condition - $80
    145mm f/4 - soft focus - excellent condition - $225
    210mm f/4 - excellent condition - $65
    300mm f/5.6 - excellent condition - $235
    One of the many benefits of an extremely open Phase One system :-).
    Capture Integration, Phase One Dealer | Personal Portfolio
    Aug 2008
    2,535
    184
    There may be a misunderstanding here - perhaps I have not been very clear.
    First, the older Mamiya lenses WILL fit the newer cameras.
    Second, you CAN get autofocus confirmation - the green dot - of manual focus
    Third, in my experience and according to the Phase 645 manual, stop down metering will NOT work. It gives readings that are way underexposed at full aperture, less so as the you approach minimum aperture.
    But I agree completely with Doug re lens quality. I use mostly "D" lenses which are all state-of-the-art. I have an old F1.9 "N" lens for things like the northern lights, where the wide aperture is more important than resolution. I also have a 200 mm 2.8 Apo which is just a tad sharper than the already very sharp 210 mm AF lens. But because I can't get stop down metering to work, I'll sell this lens.
    I'd love to hear from other Phase/AFDIII users about their experience with the older lenses.
    Bill
