Results 1 to 10 of 10
Thread: Hasselblad H3DII-31 and PocketWizard FlexTT5
    Feb 2012
    Brooklyn
    84
    Hello GetDPI.com forum!
    I recently picked up a Hasselblad H3DII-31 and beside conventional PocketWizards, I also have a set of FlexTT5's and AC3 controller. I love this system and use it with both speedlites and strobes.
    I had the FlexTT5 and AC3 controller working with the Hassy. As a test, I was was able to trigger a Nikon speedlite thru the 9 stops of flash power remotely with the AC3 controller. Then I tried again to use the FlexTT5 and nothing. Even reset my units to factory default.
    The FlexTT5s are working with each other as well as my Nikon D3s, but they stopped communicating with the Hassy. According to PocketWizard, the latest firmware release supports manual use with virtually any camera, so I'm stumped.
    Anyone have any experience with this?
    Thanks, Adam
    Member Douglas Fairbank's Avatar
    May 2012
    London
    35
    Re: Hasselblad H3DII-31 and PocketWizard FlexTT5
    Check that the metal end stop on the accessory shoe of the prism is not bent. You will probably find that the pocket wizard is not making connection to the shoe.
    Jan 2009
    Jeddah / Saudi Arabia
    126
    Adam,
    maybe this is a stupid hint, but in case you used the PocketWizards on a Nikon in the meantime and activated TTL mode, you need to set the Flex units back again to manual mode via PocketWizard Utility.
    As a side note to Douglas' hint, try to bypass the hot shoe connection with a pc cable between H camera body / digiback and the Flex unit.
    Good luck.
    Udo
    Feb 2012
    Brooklyn
    84
    Thanks for your input. I am only using Manual and have determined that the FlexTT5 must be pushed quite tightly into the front of the hotshoe in order for it to properly make contact. So for now, I got it working again.
    The cool thing about this system is that with a FlexTT5 and AC3 controller, you can remotely manage 9 stops of flash power individually across 3 groups. Saves a lot of time running up and down C-stands!
    Adam
    Yasmin
    Hi Folks:
    I want to try this too, but could not find details on PW site.
    How does this work? Should I switch every thing to Basic Mode or CTTL?
    Can AC-3 have to be on camera ?
    Yasmin
    Feb 2012
    Brooklyn
    84
    Quote Originally Posted by Yasmin View Post
    Hi Folks:
    Yasmin
    Hi Yasmin,
    I am using FlexTT5's and AC3 controller with my Hasselblad H3DII-31.
    Here's what you need to do:
    Update ALL of your FlexTT5's the the latest firmware via the PocketWizard Utility. You'll need to connect the FlexTT5's to your computer via USB, then open the utility etc.
    When using the FlexTT5's, you must use them in Manual (M) mode. TTL will not work. In Manual mode, you can use the FlexTT5's pretty much on any camera with the AC3 controller. I use them on my Nikon D3s, Fuji X100 and Hasselblad. I control anything from Nikon SB800s to Alien Bee Einsteins.
    Here's a recent shot I did with the Hasselblad using a FlexTT5 and AC3 controller on the camera to trigger 2 x Nikon SB800's with FlexTT5's.
    Adam
    Nick by Adam Lerner, on Flickr
    http://adamlerner.net
    Yasmin
    Thanks for the fast reply.
    My FlexTT5 sets have the latest firmwares.
    Can't wait to use them use in Manual with my Mamiya cameras.
    Sep 2010
    Philly area, PA, US
    354
    PW TT1 or TT5 transmit on both Control and standard channels at the same time. You determine the channel via the utility. They will work with any camera (in standard mode).
    Feb 2012
    Brooklyn
    84
    cool and depending on what your max shutter (1/800 or 1/1600), you should be able to sync the entire range, but will have to increase power on your lights to keep up.
    Yasmin
    Understood.
    Thanks Adam.
