Results 1 to 4 of 4
Thread: Alignment problem with Schneider Digitar lens
    Mar 2012
    Sweden
    1,538
    I have a Schneider digitar 90mm lens (copal shutter on a Linhof Techno board) which is noticably less sharp on the left side of the frame, shooting at f/11 with 33 megapixel back. I don't have problems with my other lenses so I think there may be some lens element alignment problem in the lens, or maybe some problem in the shutter thread.
    I've heard that you can send the lens to Schneider and get it "recalibrated". I've searched the web a bit and found a service center, but they are of the not-responding-to-email kind, so I don't know if I found the right place.
    Has someone got their lens recalibrated and can describe how it works, who to contact? And perhaps what it typically costs. The 90mm is a low cost lens so maybe it is cheaper to buy a new one than to get it recalibrated.
    Mar 2010
    Germany
    253
    Re: Alignment problem with Schneider Digitar lens
    Did you contact Mr. Werner? If not I'd suggest to call him. I had Schneider convert three lenses to a different mount and no communication problems at all:
    Mr. Werner Bayer
    Service Manager
    Fon: +49 (0) 671 601 298
    Fax: +49 (0) 671 601 185
    E-mail: [email protected]
    Repair service, Jos. Schneider Optische Werke
    Chris
    Senior Member yaya's Avatar
    London, UK
    1,168
    38
    I'd try to determine if it's the lens or perhaps the lens board or the shutter's mount. Take the lens+shutter off the boar and turn it 90 & 180 degrees and see of the soft area also turns
    Mar 2012
    Sweden
    1,538
    Thanks for the tips, I'll try some own diagnostics first.
    Yes I tried to contact Mr Werner but only through email (twice), no response. I'm a bit shy on the phone especially when not speaking native language (I have some problem hearing especially when someone speaks with an accent) much more comfortable with written communication, but I guess I have to make an exception here :-)
