Results 1 to 17 of 17
Thread: Lee 4" system, 95mm and wide angle
    Aug 2012
    Singapore
    32
    Question Lee 4" system, 95mm and wide angle
    Hi all,
    I've got recently Hassy HC 50-110, which has 95 mm thread and I also have lee filter system. Purchased adapter ring and found that if there is any extra filter like UV attached to the lens, on 50mm with lee system it gives some slight vignetting. Without UV - it's OK. In BHPhoto description it said "for long lenses" but comparing with other adaptor rings it doesn't look any thicker.
    The concern is that I'm planning to get 28mm, which is also 95mm. It will definitely vignetted. What are you using in this combination? Is there any 95 mm Lee adapter for wide angle?
    KEMPTEN / GERMANY
    1,513
    116
    Re: Lee 4" system, 95mm and wide angle
    WA adaptor rings are not available larger than 82mm .
    This link might help :
    The LEE Camera Filters System - Includes Filter Holders, Adaptor Rings and Lens Hoods
    Have a look into the blue box in the section : adaptor rings .
    Regards . Jürgen .
    Aug 2012
    Singapore
    32
    So, I assume the only solution is to order customised 95mm ring? Any other ideas or workarounds?
    Apr 2010
    116
    It won't be easy getting an ND grad system for the 28mm lens. Here is my solution for the Phase One 28mm lens. It is problematic to use regarding reflections back onto the lens from the filters. It also requires buying new holder and larger Lee x-pro sized ND grads. Mine remains largely unused because of this difficulty.
    For the 50-110mm zoom lens you will probably be ok with the standard push on holder with correctly sized doughnut ring and the 100mm filters.
    http://forum.getdpi.com/forum/medium...-one-28mm.html
    Member Miller's Avatar
    Aug 2010
    66
    Mike,
    On the HC 28 the 95 mm ring causes some vignetting, even when mounted directly to the lens without uv-filter. I don't think a custom ring is possible, given the diameter of the lens tube.
    Aug 2012
    Singapore
    32
    Thanks Baxter - it looks like possible way if I won't be able to do anything more standard. Meantime, I've requested Lee if it's possible to make custom 95mm ring but I'm afraid Frans is right and due to the diameter it isn't possible
    KEMPTEN / GERMANY
    1,513
    116
    Mike
    That ring , BTO , will be rather expensive .
    So you better cancel your order , when you know it will not be a solution for your needs .
    Regards . Jürgen .
    Aug 2012
    Singapore
    32
    I didn't make any order yet - just asking them questions
    Aug 2012
    Singapore
    32
    Here is a reply from Lee:
    Due to the design of the filter system, I'm afraid that it is not possible to make a 95mm wide angle ring.
    The 100mm push on holder may be OK to fit to the outside of the lens, and it will take the same existing filters from your current system.
    Aug 2012
    Singapore
    32
    Workshop Member Bryan Stephens's Avatar
    Oct 2011
    Connecticut
    463
    I used to use a Cokin filter kit on my Hassy 40mm wide, and even cut down the extra slots so the adapter I had on that lens only took one filter at a time, and it would still vignette, so since the lense is so wide, there isnt much you can do.
    What I ended up doing, was removing the filter holder, and holding the filter against the end of the lens without any adapters. Pain? Sort, of, but it did help with the vignetting issue a little.
    Bryan
    “You don’t take a photograph, you make it.” — Ansel Adams
    Aug 2012
    Singapore
    32
    Bryan, that's exactly what I'm doing with my old 40mm C T* Suspect, that might be a solution for HCD 28mm
    Oct 2011
    Connecticut
    463
    I am of the mindset that use whatever works.
    I loved that lens and camera, and sold it when my son was born as I knew my shooting time would be very limited. Wish I had it today. Instead I have a Cambo WRS, with IQ140, and now a D800 / D3s kit with way too many lenses. (whoops).
    Bryan
    Feb 2009
    1,083
    6
    I used that LEE 95mm adapter with GND filter only, and the vignetting is there, i used that on my HCD 28mm, i was thinking to go with stacking the filter direct to the lens by a sticker if possible, or by holding by hand if the speed time is not longer than 6 seconds, i don't think i can keep holding the filter on the lens many times more than 5-6 seconds.
    Good luck, if you find the solution please let me know.
    Tareq
    Aug 2012
    Singapore
    32
    Another option might be a screw-in 95mm Graduated ND. I understand that I'm loosing some flexibility with that but it might work. I have B+W 77mm screw-in grad 0.6 and used it in the past from time to time. The only problem, a choice of graduated ND filers of that size is not that great.
    Has anyone used Formatt filters? Are they good? BHPhoto has huge selection of those
    Oct 2010
    Zug/Zurich (Switzerland), Dubai, Sydney
    334
    I have the same issue using LEE and Hitec grads on my Alpagon 23HR with the CF attached. The filter holder is a no-go. I simply attach my filters directly to the lens barrel with 4 blobs of blu-tac. It looks untidy, but works a charm and is as cheap as chips. There are several other brands of sticky stuff that claim to compete with blu-tac, but I've tried most and none are grippy enough to hold a filter reliably.
    Siebel
    "In the end, it's all about the pictures"
    www.bryansiebel.com
    Apr 2009
    Sydney, Australia
    581
    2
    I asume that you are using a 60 or 50 as the 40 does not vignette. FWIW, the Lee push on adapter is something that you love or hate. I had a custom adapter made which goes on the hood bayonet, that may stop vignetting. I never use it as I have a 40 now.
    Jeff
    www.jeff-grant.com
