Results 1 to 7 of 7
Thread: Retrofitting to Alpa mount
    Mar 2010
    Southampton
    565
    Has anyone here ever had a lens retrofitted by Alpa? I read in one of their publications that they offer this service, but can't find anyone that has made use of it.
    If you have, was it pretty straightforward to do (via a dealer I'm hoping), and how much did it cost? Did it take long? Would you go down that road again or just sell the lens and re-buy it pre-mounted? I know Cambo are in the $1k - $1.5k range depending on the type of mount, and Arca (R-line) are around the $1k mark - so I'd imagine/guess Alpa charge around about $2k per lens.
    The reason I ask is that I have my eye on an STC, but only if I can get my 35mm and 60mm lenses remounted.
    Thanks in advance (would be great if Thierry was still here as part of Alpa to answer these questions).
    Jim
    smei_ch
    Re: Retrofitting to Alpa mount
    For a qualified answer I would contact Alpa directly.
    Jun 2008
    SoCal
    291
    15
    I believe our member Jürgen (jotloob) had this done. I recall a price in the range of $1200 a few years ago, quoted from Paul Slotboom, but don't hold me to that. It's done by Schneider I believe (for SK lenses of course).
    Cheers, -Peter
    Mar 2010
    Southampton
    565
    Thanks guys - will contact Alpa direct (no local dealer nearby) - will try and find out about the mechanics of doing this - i.e. import/export hassles etc.
    Will post response when it arrives.
    KEMPTEN / GERMANY
    1,513
    116
    Not all Rodenstock or Schneider lenses can be adapted to be used with the ALPA System . I am thinking of lenses we know from the LF photography .
    Each lens needs a lens barrel with the corresponding length of the focal flange length of the lens .
    To produce a lens barrel to order would surely be possible but would be extremely expensive . So forget about this .
    The retrofit is done either by Schneider or Rodenstock to the ALPA specifications . At least , that is valid for european countries .
    The ALPA team will surely give you a qualified answer and tell you how to proceed .
    Regards . Jürgen .
    Mar 2010
    Germany
    253
    I had three Schneider lenses converted to Alpa mount. Took between 10 days and three weeks if I rember correctly. I contacted Alpa, then I sent the lenses directly to Schneider and they returned them to me, Alpa sent the invoice. No problems at all.
    Chris
    May 2009
    Marseille, FRANCE
    972
    i have retrofit a 28 HR Alpa, for my Arca RM3D because the second hand market is close to zero for that type of lens...
    But, i'm pretty shure, that you can find a 35 in alpa mount...
    If your 60 is the new one, then it's worth the expense !
    here for example...
    FS: Alpa Schneider Apo-Digitar 35mm XL Lens with Center Filter
