Results 1 to 3 of 3
Thread: MFDB White Balance and Polarizers
    Aug 2012
    Singapore
    32
    Question MFDB White Balance and Polarizers
    Most if not all DB are lacking any automatic WB settings. We have 2 options - use presets or shoot a grey card. Recently I had a photo session, using Lee square linear polarizing filter and all shots come up with quite a greenish cast though I took a capture of grey card before, to set a custom white balance
    So, the question is, what custom WB technique do you use when shooting with filters? Would it be a right way to setup polarizer and then take a custom WB shot?
    NYC
    3,275
    7
    Re: MFDB White Balance and Polarizers
    Quote Originally Posted by MikeHlop View Post
    Yes, WB should be taken/made with any filters you'll be using for the final shot.
    Oct 2010
    Zug/Zurich (Switzerland), Dubai, Sydney
    334
    If you are doing anything colour-critical, you should be shooting a grey target for a custom balance. It's just good work practice.
    Every polarizer I have ever measured with a transmission densitometer (pretty much all the major brands) have a measurable cast. Most have a green cast, but I have measured a couple with slight red and also magenta casts. In most cases, the cast is very slight, but quite distinct in some cases. Price does not seem to be a factor as some of the dearest are the worst.
    If you shoot a grey target through the filter you are using and set your grey balance from that, then none of this matters.
    Siebel
    "In the end, it's all about the pictures"
    www.bryansiebel.com
