Results 1 to 15 of 15
Thread: What Do You Use for WB in the Field?
    Jan 2011
    Palo Alto, CA
    621
    Just curious as to how folks do white balance in the field (outdoors). Though I usually use Auto on my Phase, sometimes (in green forests or under cloudy conditions by the ocean) I have to do major adjusting back home.
    Someone once told me if you use a corrected LCC shot and put the WB eyedropper in the center of it, that works well. I've tried using the Gratag McBeth thing, but it's often not easy to get out in front of the lens.
    I now have live view and there is the ability to set a custom WB for each shot, but not sure of the best way to use it. Experience of others would be great.
    Thanks,
    Bob
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: What Do You Use for WB in the Field?
    I usually set the IQ180 to daylight and avoid auto completely.
    Sometimes there might be a neutral portion of the subject available for droppering in post which occasionally helps.
    I find that in most landscapes that it is not necessarily "accurate" that is best, but rather that which is pleasing so manual adjustment depending on the scene often works best.
    If you want accurate, then there is no substitute for a gray card shot in the same lighting conditions. If there be sun be sure to shoot a card in both sun and shade. Usually the wb measured off the shaded gray card will produce the most pleasing (warmer) result.
    -bob
    23,623
    2555
    +1 to Bobs post. I do use a passport color checker when needed. But always on daylight and for landscape for me its 95 percent to taste most of the time. Trick here have a great color managed system with you computers and monitors so WYSIWYG when you go to print. My Epson 7900 is exactly like my monitor setup. Very important you have this down correctly. Also very important for delivering to clients perfectly managed files.
    www.guymancusophotography.com
    Brooklyn
    4,043
    1253
    part of the problem is that a neutral gray card is only neutral in full spectrum light. so if you shoot in warm sunrise/sunset lighting, it won't really be neutral grey. so then if you wb off of the card, you will be compensating with out realizing it and your results will be cool
    23,623
    2555
    Absolutely you don't want to lose the effects of the warmer light shooting sunrise and sunsets. WB that will guarantee cooler kelvin temps. Most daylight WB cameras are set for around 5500 kelvin which is full sun bright light.
    Los Altos, CA
    10,486
    1031
    Ditto -- Daylight for the DB's, never auto.
    home: www.getdpi.com
    Jan 2011
    Palo Alto, CA
    621
    Thanks everyone. Set to daylight and will adjust to taste after.
    Bob
    Senior Member etrump's Avatar
    Jan 2009
    1,206
    All great advice - ditto on everything posted. In the study, it is just the opposite for me, always use a passport for reference point.
    Nov 2009
    Draper, Utah
    871
    134
    Quote Originally Posted by Bob View Post
    -bob
    +1
    wayne
    My gallery
    Little Rock AR
    1,927
    4
    Always daylight no matter what the conditions are. Never shoot indoors with the IQ so not sure what to do there.
    Still never understand why capture one defaults to flash.
    Is there a way to change the default to daylight?
    Paul
    Aug 2008
    Carmel/Tucson
    2,355
    Outdoors, WB set to Daylight on the IQ180.
    Indoors in studio, I shoot a controlled WB frame using a WhiBal grey card, and use this frame to help set the WB in post using C1Pro.
    ken
    23,623
    2555
    Paul
    Paul when you do use tungsten that way the crossover to a good WB is not as dramatic. As your much closer in kelvin to what looks right. Doug and I talked about this once and from memory I think it was you miss out on some of the color spectrum on a big kelvin change. Maybe he can enlighten us again on this. It sounds logical to me as much as the blue and red channels make big shifts when your jumping big kelvin temps.
    Senior Member RVB's Avatar
    Jun 2012
    Amsterdam
    807
    Just a thought.. would a sekonic prodigy color meter be useful ....
    Vancouver, WA
    5,802
    564
    Paul
    Paul,
    I assume that you are referring to the default ICC profile? I override this using a style on import or apply it to all images from the same camera afterwards if I forget.
    See also: http://www.getdpi.com/forum/image-pr...le-camera.html
    IIRC Doug also shared a way of renaming the profiles so that outdoor daylight was first (I'd have to look it up to check but I think it was as simple as renaming as 1_xxx 2_xxx etc).
    Jul 2011
    118
    I use custom WB (grey card or Expo) now regularly. I find it especially useful on leaf more than phase one.
    If you have IR back, custom WB is the only way to go..
    Amr
