Results 1 to 6 of 6
Thread: DF+ lens compatibility
    Mar 2012
    Toronto, Ontario, Canada
    105
    Question DF+ lens compatibility
    I was wondering if anyone could explain which Mamiya 645 (and Hasselblad V and Pentacon 6) lenses are compatible with the Phase One / Mamiya DF+ body and what (if any) limitations there are for the various versions that have been made over the years?
    Thanks! J R
    (P.S., this is for use with a P40+ back.)
    Vancouver, WA
    5,800
    564
    Re: DF+ lens compatibility
    I use the DF vs the DF+ but I have yet to run in to any issues with any older manual focus 645 lenses with this body. You will need to manually stop down to meter the lens as there is no coupling and they are essentially passive.
    I was able to do the same thing with Pentacon 6 glass via a mamiya 645 adapter. My first Hartblei Super Rotator was in pentacon 6 mount and it worked fine.
    Regarding the Mamiya and Phase One AF lenses, they should all work be they original AF, D or LS.
    I haven't tried any of the V glass with the adapter but I'd expect the same behavior.
    The only time I've ever had a problem was when Phase One screwed up a firmware release a while back with the DF body which wouldn't allow a non AF lens to work on the camera at all. (1.18 I think?). They fixed it and certainly 1.25 works as I described above.
    Mar 2012
    105
    Thanks Graham.
    FYI, I just found the following list on Specular: Phase One 645DF+ camera system :
    Phase One 645DF lens compatibility
    What lenses are compatible with the Phase One 645DF? Lenses with native operation (auto-diaphragm and autofocus)
    Schneider Leaf Shutter Lenses
    Schneider Kreuznach 28mm f4.5 LS
    Schneider Kreuznach 55mm f2.8 LS
    Schneider Kreuznach 80mm f2.8 LS
    Schneider Kreuznach 110mm f2.8 LS
    Schneider Kreuznach 150mm f3.5 LS
    Schneider Kreuznach 75-150mm LS
    Schneider Kreuznach 240mm LS
    Schneider other Lenses
    Schneider-Kreuznach PC-TS Apo-Digitar 5.6/120 HM Aspheric lens
    Phase One Digital Series (focal plane) lenses
    Phase One 28mm f4.5 D
    Phase One 35mm f3.5 D
    Phase One 45mm f2.8 D
    Phase One 80mm f2.8 D
    Phase One MF 120mm Macro f4 D
    Phase One AF 120mm Macro f4 D
    Phase One 150mm f2.8 D
    Phase One 75-150mm Sekor f4.5 D
    Mamiya 645 AFD lenses
    Mamiya Sekor AF 28mm Sekor f4.5 D Aspherical
    Mamiya AF 35mm f3.5 D
    Mamiya AF 35mm f3.5
    Mamiya AF 45mm f2.8
    Mamiya Sekor AF 45mm f2.8 D
    Mamiya AF 55mm f2.8
    Mamiya Sekor AF 80mm f2.8 D
    Mamiya AF 80mm f2.8
    Mamiya Sekor MF 120mm Macro f4 D
    Mamiya AF 150mm f3.5
    Mamiya Sekor AF 150mm f2.8 D
    Mamiya AF ULD 210mm f4 IF
    Mamiya AF APO 300mm f4.5 IF
    Mamiya AF 55-110mm f4.5
    Mamiya Sekor Zoom AF 75-150mm f4.5 D
    Mamiya AF 105-210mm f4.5 ULD
    Lenses that require manual stop down
    Mamiya manual format lenses including 50mm shift lens and 80mm f1.9 portrait lens
    Hasselblad 500 series lenses
    Hasselblad 200 series lenses (including the infamous 110mm f2)
    Hartblei Super-Rotator 45mm tilt-shift lens
    Pentacon 6 series lenses with purchase of adapter
    NYC
    3,274
    7
    Quote Originally Posted by JRBERNSTEIN View Post
    Ha! Phase One copied and pasted a list I made while at CI. The specific references to the 50S and 80/1.9 and the specifically phrased "infamous" 110/2 could not be a coincidence. I'm flattered!
    Other manual-aperture lenses worth noting:
    - Mamiya 500/2.8 (big and $$$)
    - Mamiya 140mm Soft Focus
    - Mamiya 24mm fisheye
    Also, any other lens, like Leica Photar microscope lenses or Canon L series lenses like the Canon 85/1.2, can be attached using the Auto Bellows or other mechanical adapter, with the additional large caveat that they may not focus at infinity depending on design and focal length (symmetric lenses less than 80ish mm long will not focus at infinity on the shortest available adapters) and they may not cover the full frame of the sensor (leading to vignette or pure black in the corners).
    Jan 2012
    1,198
    That reminds me. I must ask the good folk at Alpa if they'd be willing to knock me up an FD adapter for the FPS
    Would LOVE to get an 85/1.2 on the IQ180.
    Nov 2009
    NYC / Fairfield, CT
    72
    gerald.d good luck with that, I found f/2.8 and f/1.4 to be damn hard on the Hartblei, I can only imagine that much more....the Mamiya 80mm f/1.9N seems to be my limit for MFDB at least in terms of easy use, especially with the IQ focus mask. Focus confirmation is good but it may be hard for the OP to confirm focus with the P40+ in this situation.
